I used to have one of these. Mine had the two prong mains socket on the back. I sold it ages ago. I'm more into the old ThoughBooks now.Found this old Toshiba at work, doesnt have a PSU thought, but overall looks in good condition
I really want to mod my Dreamcast but the cost of HDMI/GDemu/PSU replacement/Fan replacement is kind of insane when I can just emulate. Not quite the same though.
Good idea.I'm making a software pack for Windows 98 Second Edition.
This is what my software pack contains so far...
Windows Media Player 9
Windows Media Player 9 codecs
VCL Player "old version"
7 Zip
PeaZip
Clamshell Anti-Virus
Some free games
Driver Patches - for onboard video and audio fixes
USB Universal Flash Drive Driver
Image Viewer
That is it so far. If anybody has some recommendations of other things I can add to it that would be great.
The old cells are likely to be NiMH or NiCd, meaning 1.2v/cell. Soldering to these types of cells isn’t particularly dangerous, but you do need a decent high wattage iron and a high temperature so as to avoid holding heat on the cells for too long. Source, I spent 15 years making up 7.2v packs of 6 sub-c NiCd and NiMH cells whilst racing R/C cars in the 90s and 2000s.I'm planing to re-cell another dead retro laptop battery but this time I'm going to make it so I can interchange AA rechargeable batteries to and from using single battery holders plus its much safer to solder to a battery holder than it is soldering directly to a battery cell. If the old cells are 1.5 volt then I can do it otherwise I'll have to work out a configuration of cells to get the correct voltage out.
