AMD demonstrates Ryzen 9 5900X prototype with 3D V-Cache stack chiplet design
Permabanned
2 Sep 2017
But that isn't true is it ? AM4 had 6 iterations of Ryzen, do you think AM5 will have only one ? Besides people like myself have invested a fair amount into the platform, £300 on motherboard, £250 for Ram plus many other items and then there is the whole hassle of rebuilding which for myself given I uses it daily for work is not something I undertake lightly so a drop in upgrade which over Zen 2 will give my upwards of 30 - 40% improvement doesn't seem that silly to me :)
There will always be something better.. I expect AMD to support releases on AM5 until 2025 at least unless the socket has some big issues with itself..
I think that it is not good to invest in a dead-end platform, and its last version.
Better buy the second generation of AM5 in 2 years.
31 Dec 2011
That's why you don't wait - just enjoy what you have now and choose a better period when to throw the money.
Ok that's your choice. But the investment isn't really that much when you consider the resale value of say my 3700x. Let's say around £200. I will then get 4 extra cores plus 40% extra for a 5900x vcache, I imagine I will find one for around £500 so only around £300 outlay when all is said and done. Just seems brilliant value to me.
TNA
TNA
Caporegime
13 Mar 2008
Greater London
Yep. Again, wasting your time. £300 or so will get you one of the best CPU’s out there at the time and last you a long time. Also what is the point in buying a platform that is not a “dead end” like all Intel ones are and not make use of the option of upgrading?
31 Dec 2011
Exactly. One of the main reasons for investing in the platform in the first place.
28 May 2007
Probably the biggest strength of AMD. The board in my sig is still going strong and supports all has support for all of the Ryzen line up. It even supports pre Ryzen CPU’s.
5 Oct 2009
Spalding, Lincs
XT varients with the 3d cache would be a nice upgrade in a year or two for me. That way I can run this system for many years to come with a good CPU before having to upgrade to a whole new platform.
9 Jun 2011
I think a faster version of the 5800X is very likely. I don't know if they will add a "t" to the end of the name though.
Personally I'd say very likely, I just don't see AMD limiting the 3D cache chiplets to the 12 and 16 core CPUs especially if the Alder Lake performance leaks are accurate.
Thanks after that single chiplet because 0 latency overhead, a 3800xt with a + 15% yes please for competitive gaming rig !
23 Dec 2020
I'm already invested in AM4 since 2019 so not an issue for me indeed - However, Zen4/AM5 might not even come out next year. DDR5 is also not that mature so personally, AM4 might be a good one to stay invested in instead of being a BETA tester with DDR5 etc..
21 Jul 2005
Officially least sunny location -Ronskistats
Agree with this. Wont be hard to migrate over once the beta testing has ironed out the bugs or even sell the AM4 gear to offset the next gen. We would be talking a way off so a sensible route IMO.
26 Sep 2010
Stoke-on-Trent
...V-Cache are with a different design.
They're not, it's the exactly same chiplet with some cache stacked on top. The power and data vias and connections on the chiplet have been there since Zen 2, AMD are only just now utilising them.
3000 XT being used for improved yields and binning doesn't exclude XT being used again. The 3000 XT was a refreshed Zen 2, 3D stacked Zen 3 is still a refreshed Zen 3, so 5000 XT makes sense.
15 Oct 2019
Uk
If they go with XT then does this mean no 6 core with Vcache?
26 Sep 2010
Stoke-on-Trent
Why would you say that? Chiplets are chiplets are chiplets, it makes no sense for AMD to just throw away any 3D cache chiplets that don't make the cut for a 12 and 16 core SKU, or "waste" golden samples that are a bit "too good" for the dual chiplet models.
Look at the chiplet allocation in the current 4 chiplet-based SKUs. Are all the chiplets the same quality? Do the 5900X and 5950X get slightly lower binned chiplets so the 5600X and 5800X get maximum performance? Or do the dual-chiplet SKUs get preferential treatment to keep their TDP down? Arguably it doesn't make a difference because there is still a binning requirement to populate those 4 SKUs, and that binning requirement doesn't go away because there's now a slice of cache slapped on top. And with yet another bump in TSMC's wafer costs and the little extra manufacturing cost to lay down the cache, I really don't see AMD throwing anything away just because a chiplet didn't cut the mustard for a 5900X.
Also consider this: AMD demonstrated a 15% uplift in games. I think the use of a 12 core model was purely because AMD had pushed the 5900X as their ultimate gaming CPU previously, so that narrative was continued. But everybody in the real world knows 12 cores is currently overkill for gaming. Even if big little works out for Alder Lake, gaming is still going to be a job for the performance cores, and Intel still only has 8 of those. Gaming perIt'll be a big dent for AMD's current performance leadership if they appear to need 12 3D cache-enhanced Zen 3 cores to contest the gaming crown against "only" 8 Golden Cove cores. If Alder Lake's synthetics prove to be real and translate to real-world usage (which Rocket Lake never did), then AMD are going to need the 3D cache performance uplift across the entire product stack.
Ultimately nobody's said which desktop SKUs are getting the 3D cache treatment, but I don't see any reason why such treatment would be exclusive to the top SKUs. And if the only argument is "well 3D stacking must cost a fortune" (of which it won't), then I can see AMD pricing Threadripper to subsidise the desktop line given there's a fight on with Alder Lake.
18 Oct 2002
West Midlands
5900XT will be 2x chiplets with 6-cores plus v-cache so the 5600X(T) or whatever it is going to be called is a no brainer. They should probably price it at $329 just to annoy everyone too. :p
