That turned out to be safe and they wanted her to double check which she did and nothing was wrong. She didn't give an unsafe gun, they wanted her to double check it was safe and it was.
Do you know why they stepped in?
Yes Hannah this wasn't her first role at the job. She had the right background and right training. When she was talking about not feeling ready that wasn't this job. That was her talking about her past when she first started out.
"What are you basing your evidence that she was hired because of her outstanding abilities on?"
The quotes from the previous staff that worked with her. Her last prop master from other films called her a very talented armorer, exceptional, professional. She was also trained by a famous expert in the field and had successful films behind her. What makes you think she wasn't hired on her abilities? Do we even know if she was on set when the accident happened as there was a mass walk out of crew due to safety concerns. What if she was part of that walk out that happened hours before the accident?
The smoking gun that claimed the life of Halyna Hutchins might've been more than just an on-set prop -- it was also being fired recreationally, even when cameras weren't rolling.
Multiple sources directly connected to the 'Rust' production tell TMZ ... the same gun Alec Baldwin accidentally fired -- hitting the DP and director -- was being used by crews members off set as well, for what we're told amounted to target practice.
Imagine spending all this time arguing (badly) about this, and not even understanding what the argument was about.![]()
Amazing. Women gets job, must be because she's related to someone, is shagging someone, because of wokeism or possibly all 3 at once. You guys just never fail to deliver.
Not for that quote. In the case of Hannah this wasn't her first role at the job. She had the right background and right training. When she was talking about not feeling ready that wasn't this job. That was her talking about her past when she first started out on her first job.
The other failures on set where not due to Hannah but the directors cutting corners.
The same directors that handed over a live gun and skipped his job to check the gun.
Dave Halls is the one that skipped the gun check and handed over a live gun saying its not live. Not Hannah.
Yes but what I can’t necessarily do is check the valve is locked or the switch breaker open. Also if you were a member of my working party where I was responsible you wouldn’t even necessarily see the document. I’m putting you to work I have to ensure you work safely. I accept it’s not the same industry but if you told me that Alec was in my working party and was following my commands I wouldn’t be expecting him to personally check the documents or isolations/controls.So your first line...you rely on documentation. The onus is on you to check the documentation is in place and therefore the correct process at least appears to have been followed. You carry out a visual check to make sure its in place. In fact I bet you go a bit more in depth and have a proper read to make sure the correct isolations or safety measures are in place? Do you check for any keys or locks to be in the correct lock out boxes?
If the documentation isn't present you don't proceed. You don't just go on the word of the person before that all is good.
They hadn't seen her check the gun and all actors have a right to ask for the gun to be checked in front of them. To quote them "We didn’t see her check it, we didn’t know if something got in the barrel or not,” one source said. Sounds to me like someone was just being careful and rightly so rather then she did anything wrong.Do you know why they stepped in?
Yes but what I can’t necessarily do is check the valve is locked or the switch breaker open. Also if you were a member of my working party where I was responsible you wouldn’t even necessarily see the document. I’m putting you to work I have to ensure you work safely. I accept it’s not the same industry but if you told me that Alec was in my working party and was following my commands I wouldn’t be expecting hi. To personally check the documents or isolations/controls.
You hit on it perfectly there with if I were a member of your working party.
You do the checks because the people working for you are at risk. Alec should have checked because those he dangerously pointed the gun at were at risk.
If that's true as the direct quotes say they didn't see her check it. So they didn't see her check it but watched her check it on the ground? Which is it? There seems to be a lot of conflicting information around and the media seem to be taking information out of context and reposting it to paint a picture that isn't 100% accurate.They stepped in because she loaded it on the ground. Thats wrong.
If that's true as the direct quotes say they didn't see her check it. So they didn't see her check it but watched her check it on the ground? Which is it? There seems to be a lot of conflicting information around and media seem to be taking information out of context and reposting it to paint a picture that isn't 100% accurate.
As for Alec there is a report the draw the gun, nothing happened put it back in the holster and then on the 2nd draw it went off so he could have checked it thinking it was clear. Also its not Alec's job to check the gun. The safety rules on set said the last person to check the gun is the director. There is a procedure to follow and chain of people checking the gun which didn't have Alec as part of that chain. Alec was following correct procedure for that set. The fault lies with the multiple people before him as those are the ones that broke procedure.
The talk coming out so far seems to suggest a failure to adhere to proper procedures from start to finish with this production.
@dowie you are taking “facts” from the gossip magazine TMZ. What’s next The Sunday Sport says woman who loaded gun is really an alien.
Here is her social media - noting both her sex and who she is related to, not just an armourer but a "female armourer" and daughter or [well-known person in the industry]:
Given the latter that's probably had a bigger effect here... or do you think it's usual for unconnected 24-year-olds out of their depth to be given "head of" type roles on movies with A list actors like this? Some shortage of people who want to work in Hollywood?
How do you know that? What if he was practicing his scene which required him to point the gun from that spot he was in towards that direction? Actors do point guns at people its there job, its what they have to do as part of the job. Anyway I am not saying he is blameless only that in this case its not his job to check if the gun was safe. He was following procedure which has the director as the last person in the chain to check the gun. We cannot blame Alec for following the heath and safety procedure set in place for checking if the gun was loaded.You don't point a weapon at someone. It's that simple. He had no reason at all to point that gun in her direction.
