- 9 Dec 2009
- Bristol
A car is a mode of transport that is designed to get from a to b. A gun is a weapon that is designed to kill.
You're welcome, glad I helped youthanks for clearing that up
There is no universal film set rules and regulations. It’s completely different in every state and then can change again if filming outside the US. There might be changes in the law after this, but it will only apply to the state they were filming in.
Don't worry dowie we all know that you and dis are gonna go on and on about how you follow every safety procedure to the letter do all your own maintenance perfectly check your fluids, tread, pressures and pads every time you get in the car etc etc
Yeah, I never check if it's clear when I pull out onto a main road, someone else in the car should simply tell me - just say "clear road" and I'll trust them.
The LOLs are coming from inside the thread!
Posts in Thread:
Alec Baldwin fatally shoots woman with prop gun on movie set
Posts in Thread:
Ah man, not even on the podium.
Probably because i had to get out and check the wheel nuts were done up right after my pit crew changed my tyres. Better to be safe than sorry though!
It's not as if the driver isn't right there when it's done. Infact...wasn't one of the many suggestions that could have saved this woman's life was to have the user witness the check? Ah yes, yes it was.
the driver can’t verify everything has been done correctly from the very limited view they have from the cockpit so essentially that means nothing , even if there was a way they could then they would have to have some detailed knowledge to confidently say everything was ok
not to mention how could they rely that all the tools used are calibrated and set to the correct torque etc
No but he can carry out a basic visual check from the drivers seat. And as has been said literally dozens of times a basic visual check would have verified the status of the firearm.
Hot take from select armchairs of OCUK that the acting talent should be checking for live ammunition on a film set where live ammunition is forbidden and should know what live ammunition looks like as opposed to varieties of blanks or dummy rounds which are allowed on a film set.
That kind of responsibility regarding dangerous devices sounds like it needs a qualification, maybe even a job title like... armourer... or assistant armourer...
There's other hazards the acting talent will be near or operating on set. Assorted pyro, compressed gas devices, face breaking stunts. Is there something especially trivial about firearms that the acting talent should be expected to double check the work of the professional(s) in charge of it.
Lets imagine the blood pressure of the director as the acting talent costing 50,000 a day doubles up as a qualified general safety officer on set.
That is taking it to the extremes. There are plenty of actors who have said the armourer or authorised prop person will show them the gun is unloaded for themselves or they will check it themselves. Basic firearms checks aren't that difficult and someone handling a firearm should be familiar with the basic operation. Being under direct supervision slightly changes the equation there but one of the first things you are taught before you are allowed to handle firearms in any kind of professional setting is to not take someone else's word for the status of the weapon and that should be the same on movie production as anywhere else - the only slight exception to that is when under direct supervision where the instructor is always hands on as happens at turn up and shoot places like the ranges at Las Vegas, etc.
Actors generally won't be in the loop for pyro and other stuff like explosives which will be entirely operated by professionals.
If we can agree that pyro and explosives are far more dangerous yet the actors are expected to perform on trust then we should be able to agree that an actors unqualified approval on smallarms is not actually a meaningful safety check. It may benefit the actors confidence in handling the device for the armourer to go through it with them.
