- 28 Oct 2021
- East Grinstead
Is anyone aware of a released AIO 240mm cooler for the LGA1700 socket yet?
4 core processors are still part of Intel desktop lineup. Laptop market is dominated by 4 core models.Imagine 4 cores was still a thing today. Horrible thought. Remember you had to spend a lot from Intel to get the Hex core platform.
For some, the motherboards have shipped but not the CPUs lol. Just need someone with the cpu to meet up and benchmark.How will they bench the CPUs if no boards are shipped yet though?![]()
This is what I was getting at. As an arch, the Gracemont E cores are pretty much the same as Skylake cores with HT. So as cores, they're none too shabby. The letdown is Intel stitching them together as you say.It might be on par until a point. Ie the cache isn’t being pushed hard and the latency from the mesh NUMA arrangement is suitable to the work load.
Anyone care to speculate if current LGA 1700 motherboards are likely to support Raptor Lake / 13th gen CPUs?
When was the last time Intel released a board for a new CPU, then let you upgrade to the succeeding generation on the same motherboard?
This is likely to be a deciding factor for my dad's PC. If not, maybe I will recommend Zen3 with extra cache.
Is there any chart that confirms that?Raptor lake (13th gen) will be LGA 1700 for sure , there is even talk of Meteor lake (14th gen ) also using LGA 1700 as apparently Intel want to change to a 3 year cycle rather than 2 from previous generations![]()
I'd imagine it would be around 80-100w for a normal gaming workload.
what's your 5950X pulling in games?
Will that only be for the DDR5 boards though? as I can't imagine Intel going with the dual memory controller for 3 generations?Raptor lake (13th gen) will be LGA 1700 for sure , there is even talk of Meteor lake (14th gen ) also using LGA 1700 as apparently Intel want to change to a 3 year cycle rather than 2 from previous generations![]()
Lol, people keep comparing the AMD's 5600X to a 12600K, not remotely fair, it should be compared to a 12400, which actually has the same number of cores. I think the 12400 will keep up, despite the limited all core clock speed of 4ghz.
Would need confirmation on the different chipsets to know for sure. There's rumours here that there will be new chipsets for Raptor Lake, I suppose around October/November 2022, here:
https://videocardz.com/newz/amd-am5...n-q2-2022-raptors-lake-z790-series-in-q3-2022
It's a shame there probably won't be a 12400K, I suppose people will have to get the 12600K instead to overclock. It looks like clocks of around 4.9ghz should be achievable on most 12600K CPUs, judging by the turbo boost frequency spec.
At least the Turbo Power of 150w is an easy figure to understand (if it applies to the all-core turbo boost power usage), and probably won't run ridiculously hot like Rocket Lake CPUs.
