Mine has been fine so far. 6 Pro. I have only had to top it up twice since Tuesday, top it up to about 60% & it's been fine.How's battery life on the Pro? Is it bad as mkbhd said it is?
Today is the first time i've charged to 95%.
Can't speak for the Pro, but my std 6 was at 100% around 9:30 this morning, and I've absolutely hammered it while on 4G and WiFi (work? It's Friday, it's been a bloody long and busy week!) and it's only down to 77%.
My mate 20 pro next to me has been on WiFi only, has barely been touched, was at 100% at 7:30 and is at 86% currently..
The only way of seeing that is to add up the display time under system, right?2hrs sot today, 76% left.
Settings - apps -> screen timeThe only way of seeing that is to add up the display time under system, right?
Over 2hrs SOT for me since 100% and same, 74%.
Mate 20 Pro is at 41 mins SOT and 84%.
AHH nice, thanks!Settings - apps -> screen time
That is "today" so anything after midnight but due to early start yesterday I was deep asleep by midnight![]()
EDIT: Used the phone for a bit, then left it and came back 10 mins later. Now the AOD is only showing the gesture bar. Nothing else.
I had this last night on my P6 Pro, the screen was completely unresponsive, just had the bottom gesture bar which was also unresponsive to taps swipes etc. I pressed the power button to turn the screen off then I tapped the screen and the display came back fine. Weird...
Read that wrong then fella , my mistake. Actually missing the Mate 20x's screen size to be honest , gave the UI a less cluttered feeling than the Pro does.
You can always lower the density down from default to small. That'll make things smaller and space stuff out a bit more.I had issues this morning with Android Auto to the point that I left it disconnected and listened to the radio instead. The battery icon on the screen was flickering between charging and a full battery constantly before it disconnected.
Wonder if it struggles with what to do with power when the battery is fully charged. When I drove home after work yesterday there was no issues, but the battery was around 70% so was taking a charge normally.
The first time I plugged my P6P in to charge (Google 30W charger, Anker C to C cable), the phone appeared to start and stop charging a few times, but it hasn't done it since. Heard the charging sound a couple times.
I'm not sure if this is something to do with initial negotiation? It hasn't done it since.
I've just checked and you can't set double tap to activate the torch. You can set it to open an app though, so maybe you could find a torch app on the store?
The back of the phone. It's under system then gestures.Double tap on what? I'm lost now!
Wow that's cool!
Not sure what to do with that, maybe launch camera as I find pressing power twice quick enough to be awkward, probably because I'm left handed.
