Deleted User 298457
Deleted User 298457
Happiest man ever here with my F770. 3 cars later and still going strong.
No idea what power box is? I've had it on 3 cars without. Parking mode just monitors voltage and turns off once it has gone as long as it can.F770 needs the power box for parking mode, do you have that? Is it all ok?
Ah right gotcha - no, 100% no powerbox required.I thought the F770 didn't monitor it and you needed the power box that did this for you?
Obv you know, as you have one.
Hi All,
My budget Yi camera has packed in / having an issue with my Passat Auto start/stop system. It seems the on battery has packed up and when it powers off its corrupting the SD card.
Could anyone recommend a camera for a budget of around £40-£60 please? Ideally fairly small, with a battery to cover the above
Many thanks in advance!
get yourself a battery pack for dashcams first
Cellink B
or
Cellink neo 6 or neo 9
i have the neo 9 and its well worth the money
So forgive the lazy post but I'm after a hardwired dashcam for my car but I don't have a clue what to get. I want something good, budget it open to suggestions, if it's worth he money I'll consider it.
What are the recommendations?
I have a 12v in the boot so could do rear too, is it recommended?
I like the look of that Blackview, nice and discrete. I don't want some big horrid digital camera looking thing hanging from the windscreen.
Edit, can that be hardwired I take it?
The rear camera plugs into the front camera for power+data.I have a 12v in the boot so could do rear too, is it recommended?
