No i mean vivid, it does look very nice on hdr effect though as well but gets a little too bright for my eyes after a while.Game Mode: HDR Effect
If you mean that?
awesome monitor isnt it, LOVE mine, i have the tiniest bit of bleed in left corners but hardly anything to talk about, what mode are you gaming on? ive found vivid to be one of the best on my monitor
Ah i think its set to gamer 1 as standard, you should try vivid and hdr effect, both look really goodOut of the box settings are perfect for me at the moment. Might tinker with it later.
what you think? i switch between vivid and hdr effect although i keep it on vivid 95% of the time, i find vivid looks crisp and sharp with great colours but not too bright so you get eye strain after an hr gaming.Mines on vivid now yeah.
Cool, enjoy your new monitor and get some gaming doneI much prefer vivid, HDR effect is a bit too much.
I have 3 all on DP , had no issues , windows 10 . Maybe a faulty display port on monitor? Maybe rma? Not sure . All 3 of mine never blank out so it defo shouldn’t be happening
Mines being delivered between 11:36 and 12:36, excited!
@Firegod You got another Display Port cable to try? Are the connectors all good, not loose etc?
But I've been on for an hour or so this afternoon, and no problems on HDMI.
What mode are you gaming on?
. We will get her something sorted out, at least she is getting her work done.
But if the coil whine stays away (not too bothered if gaming as the speakers will be on) and the screen remains stable, I'll probably keep DisplayPort. Otherwise, I'll go back to HDMI at 144Hz.Playing FM5 at QHD 180Hz and smooth sailing with my 3060 Ti Founders.
Have noticed mine dim a little then get a tad brighter again...didnt think anything of it until you mentioned..mine dosnt seem to do it that often, well if it does then im not noticing but it did do it just now when surfing the net.Set mine up today and for sure it has a lot more bleed/glow in the bottom left corner than my Dell U2312HM. Tons more. Initially it is very distracting.
*However* I had to send back 2x Dell to get the 3rd which was a very good example. I only did that because Dell paid for the return and collected from my doorstep.
This time I suspect I will just have to live with the issue
That said, I'm having a different issue that concerns me.
The backlight brightness keeps stepping up and down; there is a noticeable change in brightness every few seconds. I'm not sure if this is a "feature" - and it's not local dimming (dynamic contrast, etc), because it happens on static content. The backlight will either dim or brighten, almost at random. I've also observed it stepping up for a second and then stepping back down immediately. Most odd.
I'll take some photos of the backlight bleed when I can turn all the lights off without others complaining![]()
