LG 27GP850-B
21 May 2018
South Wales
awesome monitor isnt it, LOVE mine, i have the tiniest bit of bleed in left corners but hardly anything to talk about, what mode are you gaming on? ive found vivid to be one of the best on my monitor
Out of the box settings are perfect for me at the moment. Might tinker with it later.
17 Jan 2016
isle of wight
Mines on vivid now yeah.
what you think? i switch between vivid and hdr effect although i keep it on vivid 95% of the time, i find vivid looks crisp and sharp with great colours but not too bright so you get eye strain after an hr gaming.
do love hdr effect also but like i said it does get to me on long gaming sessions, eyes not as good as they once were, old age lol
12 Sep 2003
Newcastle, UK
I have 3 all on DP , had no issues , windows 10 . Maybe a faulty display port on monitor? Maybe rma? Not sure . All 3 of mine never blank out so it defo shouldn’t be happening
Mines being delivered between 11:36 and 12:36, excited! :D
@Firegod You got another Display Port cable to try? Are the connectors all good, not loose etc?
Just to add i think I was lucky with the panel as well. Small amount in lower left but I expected some. Totally cool either way and not noticeable (at least not to my aging eyes lol). Erm with regards to DisplayPort, yeah I think I'll go in the loft and grab the stock cable out of the box and try that... and if the same thing happens then it has me stumped. I had the exact same issue on my old Samsung 27" monitor, hooked up to my old Vega64. So I always used that setup on HDMI. My rig is now completely changed, every component is new (CPU, Motherboard, GPU, Power Supply, etc) and now the new monitor. The fact I still have the issue (i.e. it has followed me) must mean it is the cable. I'll report back when I try it. :) But I've been on for an hour or so this afternoon, and no problems on HDMI. :)
Really nice monitor, and for £298.99. Wow even better. Hope everyone is enjoing them.
12 Sep 2003
Newcastle, UK
Here is a bad photo of the panel uniformity on mine in a darkish room (sorry it isn't the best quality). I just used a darkish Firefox theme, and took a quick snap, hope it gives you an example @dcsarge.
It is pretty uniform, just hte bottom left has the slightly lighter glow. Maybes a tad in bottom right but mininal.
19 Dec 2008
Nowhere
@Firegod Thanks for that, it is interseting to see another panel. This is the one we have at 40% brightness, which on camera doesn't look massively different but glow on on the left hand side is still very noticable to the eye when the room lights are on and the screen looks washed out, even compared to the Gigabyte with it's terrible orange bloom issues. (BTW I know I haven't activated Windows yet before any mentions it, still haven't finished setting up the new build fully while sorting out the monitor :p).
OC support have said it normal but are issuing a return under standard rejection window, which is great. The only problem is what to do now, as I don't want to waste OC's time and expense changing monitors?
25 May 2013
Kent.
I'll try a lightbleed test later tonight. At daytime however it seems fine. Got a pretty good mix of settings now where the colours are vibrant but not too bright.
19 Dec 2008
Nowhere
Been a busy day and I didn't get the RMA the first time so it turned up late afternoon. As it my daughter's 20th today I we have been distracted :D.
I need to find a courier that will take a monitor for the return, which I recall from forum posts might be a pain. The RMA also suggests packing it in a exterior box and not attaching anything to the product box itself, which definitely got a raised eyebrow from me.
I am honestly glad to see a lot of happy new owners, I expected the monitor to be the worst bit of a new build :p. We will get her something sorted out, at least she is getting her work done.
12 Sep 2003
Newcastle, UK
I've been testing another DisplayPort cable (the one from the box). I'll see how it goes for the rest of the day, but so far it seems stable. This has revealed another issue though; 165Hz gives off noticeable coil whine from my PC / GPU. My PC is pretty near silent as the fans are linked to CPU temperature, so unless gaming, the PC is very quiet indeed. And if I open up a web browser or anything "graphical" you can here it start making electical noises. Close the app, and it stops. I think I've managed to stop it by undervolting the GPU. It seems like 165Hz is destined to give me trouble! :) But if the coil whine stays away (not too bothered if gaming as the speakers will be on) and the screen remains stable, I'll probably keep DisplayPort. Otherwise, I'll go back to HDMI at 144Hz.
Caporegime
17 Feb 2006
Cornwall
Set mine up today and for sure it has a lot more bleed/glow in the bottom left corner than my Dell U2312HM. Tons more. Initially it is very distracting.
*However* I had to send back 2x Dell to get the 3rd which was a very good example. I only did that because Dell paid for the return and collected from my doorstep.
This time I suspect I will just have to live with the issue :p
That said, I'm having a different issue that concerns me.
The backlight brightness keeps stepping up and down; there is a noticeable change in brightness every few seconds. I'm not sure if this is a "feature" - and it's not local dimming (dynamic contrast, etc), because it happens on static content. The backlight will either dim or brighten, almost at random. I've also observed it stepping up for a second and then stepping back down immediately. Most odd.
I'll take some photos of the backlight bleed when I can turn all the lights off without others complaining :p
17 Jan 2016
isle of wight
Have noticed mine dim a little then get a tad brighter again...didnt think anything of it until you mentioned..mine dosnt seem to do it that often, well if it does then im not noticing but it did do it just now when surfing the net.
