He’s too edgyLet’s not start chucking the term fanboy around and have a civil debate, shall we?
They knew of the potential problem before quali started so the argument is they could have fixed it.So only one side of the Merc rear wing failed the test, the other side and the middle passed?
Sounds very much broken then. The wing assembly was taken away, and Merc still haven't seen it... Anything sound iffy about that?
Normally if something breaks in quali, you can replace it with another part of the same spec for scrutineering. But this, nope.
What a great sprint that was.
I agree, I’m shocked.So only one side of the Merc rear wing failed the test, the other side and the middle passed?
It stinks. Anyway, it’s fired up Mercedes and it’s fun to watch. I doubt Hamilton can win the WDC, what what a win it would be.
I don’t think any of them had an answer for that pace, he was all over them - straights, braking zones, corners.
I don't disagree but I expect it will take him a bit longer to carve his way through as tomorrow there will be championship points at stake. Today there was nothing to gain for them as they knew that with his penalty he's likely to start behind them anyway. With Merc pit stop strategy being a bit off recently, keeping him back a few corners/ laps might pay off at the end of the race
No I wouldn't I would have said the same thing it's the fanboys like yourself who always see with rose tinted specs
That doesn't matter a jot. If he ran a wing which, whether it broke or not, failed the test yet didn't obviously give a disadvantage (indeed an almost certain advantage) there was only ever going to be one outcome.So only one side of the Merc rear wing failed the test, the other side and the middle passed?
Still here *waves*. Had to put the little one to bed.So.. where are all the doom mongers now? He wins the race tomorrow based on that.
Do you guys think that qualifying disqualified was OK? Or harsh or wrong from fia?
You've hardly got an exclusive on that. Hamilton was expected to take an engine penalty before the cars even arrived in the country.Max is going to come out of this race weekend with a bigger points gap than he had going into it. You heard it here first.
Anyone else feel like the DRS effect was a bit too strong today?...
It was my mistake… reading the decision back it says that had they spotted the problem earlier they could have fixed it under parc fermeHaven't seen anything that shows they knew anything about it before Quali. Just post quali, when the gauge was pushed into the (for the want of a better term) 'flap gap' and the wing also passed the static test which is what's stated as the test in the regs. It's a non-binding technical directive that states a maximum of a 10Nm force to be applied. Ok then? How is the force applied? Gentle shove, pneumatic cylinder? Is it calibrated?
No, Hamilton was just too quick. Max couldn’t overtake bottas with drs.
