- 12 Jun 2006
Anyone else getting really bad performance with a 5700XT? I'm getting like 70 fps with mine and a 3700X on the lowest settings at 1440p...
cpu gets hit more than gpu try setting highest on 1440p? it still the same? if so its CPU bottleneckAnyone else getting really bad performance with a 5700XT? I'm getting like 70 fps with mine and a 3700X on the lowest settings at 1440p...
Almost everyone is having problems with performance, the game is poorly optimised. I have 3x different rigs - and it sucks on all of them.
And those that aren't are probably as one person said " I don't have any issues on my RTX, I'm running all on LOW "
I have tried a couple of drivers, the new one and the studio driver someone suggested in this thread, both were way worse for me so gone back to octobers driver and its better again.back to old driver and works fine .. no crashes
use portal no issues thereAnyone getting he error unable to load persistence data when trying to join games? Driving me nuts!
has anyone on here tried running in dx12 by changing the setting in documents? its the only thing i havent tried
Ahhh ive just seen a few vids on the you of tube that said it made a difference but couldnt be bothered to try it lolIt doesn't make any difference, apparently that's old config left over from BF5. Also - AFAIK 2042 is a native DX12 game, so it's physically impossible for it to be running on DX11.
Try disabling crossplay, that should work.Anyone getting he error unable to load persistence data when trying to join games? Driving me nuts!
Running a 5700XT with a 9700K overclocked to 4.6. I get around the 100 fps mark all on low on 1440pAnyone else getting really bad performance with a 5700XT? I'm getting like 70 fps with mine and a 3700X on the lowest settings at 1440p...
Which mode are you playing?Running a 5700XT with a 9700K overclocked to 4.6. I get around the 100 fps mark all on low on a 1440p
AOW conquest i play mostly with the odd breakthrough game, not dipped into Portal or Hazard yet.Which mode are you playing?
I'm getting 70 fps on AOW and around 110 in Portal.
