ah thought quick launch was the search in W7, its not its is the odd extra icons..
which icons did you use?
I like some aspects, honestly the start menu and the some aspect of the revamped ui I like. However I don’t like the mix of some ui elements, unless there’s a way to go back to the classic right click menu or customising the actions I use into the first section?
e.g with 7z i right click an archive, then in win 10 I’d use the 7z menu items to choose an action, now I have to press more actions or whatever the bottom option is to then show all the other non standard options to acces the 7z menu.
If you get StartAllBack (its like $5 for a key or like £3.85) it gives you the "classic" right click menus. Can get small taskbar icons, different start menus. Loads, I have it and I love it. Mainly for the right click menus and small taskbar icons though.However I don’t like the mix of some ui elements, unless there’s a way to go back to the classic right click menu or customising the actions I use into the first section?
My main gaming machine is an HP Omen gaming laptop i7-10750H with a 2060 full fat GPU. It's been nagging me for a bit to upgrade to Windows 11. I've read a few reviews of W11 and so far it appears to be a mostly positive reception it has received, but I wondered what folk thought about doing so just now? Has anyone here went to W11 and seen no real issues with their normal gaming activities?
Or would it be prudent to hang fire until the first big W11 patch in a month or two? I'm thinking I might dual boot to try it out for a bit. Thoughts?
ok agree with rest, butWhat did I put there?
I use it for apps I use frequently, very convenient way of doing without opening start menu or search bar, its superior to pinned items as they smaller take less screen real estate and wont move around which pinned icons can do.
I am going to contact the startall dev dev to see if he can mimic the functionality.
I am not a fan of the new right click context menu though
No problems for me and I've had it on my desktop and laptop for the last month or so.
I quite like the UI changes especially the task bar in the middle with an ultrawide screen, it's much more comfortable. I am not a fan of the new right click context menu though
Thanks folks, appreciate the replies. For those who have went to W11, have you done an 'in place' upgrade and overwritten your W10 install or did you do a clean install using Rufus or similar? Ta.
