I have, X1 Carbon 4k @ 60hz and G15 Zephrus 4k @ 144hz both over USB-C.
Did you have to do anything other than plug in? Also are you using the KVM option?
Just plugged in with the cable i ordered supporting 4k60 and it worked with 4k144. Yes at the KVM, works well just a bit slow to power up k/b from sleep.Did you have to do anything other than plug in? Also are you using the KVM option?
Possibly, vague memory but i'm sure i tried a few onhand USB-C cables i already had inc some '65w' ones but they didn't support above 4k30. Searched the Rainforest and grabbed one listed as 4k60 video. Figured nothing to lose because if it didn't work at that i'd just send it back at no cost / loss.Cheers maybe I need a new cable.. have same the same slowness waking too..
ASIN: B094CCJMFV
Yeah the kvm lag is irritating but liveable and hope it improves with fw.
No, afaik the USB port on the monitor only supports 15w PDDoes the laptop charge as well with that cable?
You can set the KVM to switch between devices with one press and share all attached usb but one must use USB-C as it’s upstream and the other use the USB-B as it’s.
So I used USB-C with my MacBook for data and display and then DisplayPort and USB-B for my PC and share microphone, mouse and keyboard across them both with a single button press![]()
Thanks! Sounds good. I have a KVM switch and USB hub sprawled across the desk at the moment so would be a bonus to tidy that up!I find MacOS can get confused when I switched between devices while something like a microphone or webcam is in use, but usually because it doesn’t expect it to just vanish like that
Other than that it works really well, I even daisy chain a number of USB hubs with loads of stuff.
As far as I'm aware there are no fans in this monitor. It's perfectly silent.Havent been able to find it anywhere - does anyone know if this monitor has a fan in it?
F07 has been out for over 2 months now, IIRC F06 was pulled because of some bug with DisplayPort.07 firmware is out for the M28U but it has the same description as 06 had so not sure what has changed.
