- 2 Jan 2012
- UK.
Just tell windows not to install drivers as standard is a much easier fix.
You can do that now?
I know there was something in Windows 10 but apparently it doesn't work.
I don't want to go around hacking my registry.
Nvidia Hotfix Driver 496.98
The hotfix addresses the following issues:
- [YouTube: The YouTube web site randomly displays extreme contrast/gamma while idle or during video playback. [3420164]
- [Notebook]: Black screen may be observed on some Optimus notebooks with 1440p/165hz panels when in discrete GPU mode [3426730]
- Games do not launch correctly on GeForce GTX 750 Ti when NVIDIA Image Scaling is enabled
- [3442778]Using Adaptive Vertical Sync while G-SYNC is enabled may result in random black screen [3437003]
- [Red Dead Redemption 2/Doom Eternal]: The game crashes with TDR or the system crashes while running the game. [200766423]
https://nvidia.custhelp.com/app/answers/detail/a_id/5281
do you think nvidia will ever be able to release a new driver without having to bring out a hot fix a few days later.![]()
I need to know this also for running on a GTX470.any way to hack this driver to work on my GT 730 so can use image scaling?
There are various modded drivers iv come across, some unlock more than 3 simultaneous video transcodes and some do other stuff.
Still looking at options. Xtreme g drivers seem interesting
I am hoping some day they add back adaptive power mode, the new normal mode (which is old optimal power mode) is gimped it has less aggressiveness ramping up clocks so in many games I play I have to use prefer max performance, because gigabyte and co didnt use proper components.
Never, the nature of software development all the edge cases will never be fully tested & as its a GPU driver their are trillions of tests & areas to check for every driver.I think the devs do it on purpose to make sure they keep in a job!
I've used XTG drivers in the past but never found them to do anything the official drivers don't do.
Would be nice to have more power saving features built in as I don't always need screaming high clocks and I know I can undervolt/underclock in AB but it would be nice to have a 1 button solution within the driver like AMD has in theirs.
This new Game Ready Driver provides the best day-1 gaming experience for ICARUS, which utilizes NVIDIA DLSS and NVIDIA RTX Global Illumination (RTXGI) to maximize performance and image quality. In addition, this new Game Ready Driver offers support for the latest new titles including Chorus and Halo Infinite.
Added support for the GeForce RTX 2060 12GB
[Doom 3 BFG Edition]: The games shows corruption upon launch. [3407653]
[You Tube]: The YouTube web site randomly displays extreme contrast/gamma while idle or
[NVIDIA Image Scaling]: After performing a clean install or over install over version 496.49,
NVIDIA Image Scaling resolutions do not appear in the game. [3434708]
Games do not launch correctly on GeForce GTX 750 Ti when NVIDIA Image Scaling is enabled.
[3442778]
panels when in discrete GPU mode. [3426730]
[Notebook]: eDP panel cannot be lit when booting to the desktop after switching to discrete
mode. [3423400]
Using Adaptive Vertical Sync while G-SYNC is enabled may result in random black screen.
[3437003]
[Horizon Zero Dawn Complete Edition]: After attempting to change resolutions, the resolution does not change and the game falls out of IFlip mode. [3442862] To apply the new resolution, press Alt+Tab.
[Supreme Command:Forged Alliance/Supreme Commander 2]: Performance drop when there is mouse movement. [3405920]
[Deathloop][HDR]: TDR/corruption occurs in the game with Windows HDR enabled. If this issue occurs, toggle the Windows HDR setting.
Sonic & All-Stars Racing Transformed may crash on courses where players drive through water. [3338967]
In multi-monitor configurations, the screen may display random black screen flicker. [3405228]
[HDR][G-Sync]: Mouse pointer gets stuck after turning on HDR from the Windows Control Panel or after toggling G-Sync from the NVIDIA control panel. [200762998] To work around, click the mouse (right or left button). The mouse cursor will be sluggish for a few seconds before returning to normal operation.
[NVIDIA Advanced Optimus][NVIDIA Control Panel]: After setting the display multiplexer type to “dGPU”, the setting is not preserved across a reboot or resume from S4. [200779758]
[NVIDIA Image Scaling][Desktop]: The screen moves to the upper left corner on cold boot when Image Scaling is applied to the desktop. [3424721] Do not apply NVIDIA Image Scaling to the desktop. It is intended only for video upscaling or for games which do not run with a scaling resolution unless the same Image Scaling resolution is applied on the desktop.
[NVIDIA Image Scaling][DirectX 11 video apps]: With Image Scaling enabled, video playback is corrupted or results in a system hang after performing an HDR transition. [3431284]
