Artifacting my way towards 3100MHZ, fastest pass so far at 3090 in wattman
free photo hosting and sharing
Settings?Artifacting my way towards 3100MHZ, fastest pass so far at 3090 in wattman
Careful you don't blow it up.Artifacting my way towards 3100MHZ, fastest pass so far at 3090 in wattman
He is doing Lisa's work for her. Joking aside, If we can get someone to confirm stable settings with voltage unlocks, 6900XT might turn out to be a virtually flawless card (excluding RT).Careful you don't blow it up.![]()
Yes should be okay if your PSU is good.Guys with this having 3 8pins am I ok to use just two cables from the power supply, obviously one of the cables having 2x8 on it.
I've been doing this with my 750W Corsair SFX PSU as it only has 2 x 8 pin connections. It's been running fine.Guys with this having 3 8pins am I ok to use just two cables from the power supply, obviously one of the cables having 2x8 on it.
Im using the Corsair Premium Sleeved cables with an RM850x and they are great.RM850xThanks for the answer. Suppose I could buy them rather sexy braided cables and run 3
Now I feel guilty lolCouldn’t you of lied and said they are terrible so I don’t buy them![]()
That is what I have done with 8pin extinction cables on as the corsair standard cables look horrible but not doing crazy overclocks.Guys with this having 3 8pins am I ok to use just two cables from the power supply, obviously one of the cables having 2x8 on it.
It was even better when their super saver delivery was free.
I tried my best but still can't sort out cables/tubes coming out from the card.
1337mv, that's really pushing it. I think 1.2mv should be ok as a daily driver given it is the default voltage for many new 6900XTs and I am just aiming for ~2700Mhz. My only concern is that my card is a reference (from Sapphire) and this setting does change the boost behavior related to voltage.Ive been running 3000mhz in wattman@1337mV for a couple of days now. Forgot to dial back MPT before gaming. So apparently its stable enough for gaming.
You are going full-throttle on the power limit. Does playing around with the Frequency tab nets a significant benefit? You might wanna be careful with those voltages https://www.hardwareluxx.de/communi...-wakü-lukü-ln2.1282285/page-682#post-28854289 .
