how do you connect to the switch?That's what I figured too - I opened mine up when it arrived the other day as it has a couple of metal weights in. Took a good 15% off the weight of the controller, so much better for the kids.
mine doesn't recongise it, and loads of reviews on amazon people say the same thing
I got the gamory one too.I'm not overly convinced everyone is receiving the same unit. The one I have (that came off that link previously) is branded Gamory and I took apart and couldn't find any weights.
The pairing on these things is always hit and miss but connecting with the cable is the only way I've ever had success and that generally involves mashing many buttons till it picks it up
It's in the change grip / order section but try your own USB-C cable if you have one and not the flimsy one that came with it.
Sorry didn't get your quote in time to help. Yes the pairing process is a bit weird, I tried to get it working wirelessly on my pc too but didn't have any luck. So far so good on the switch though.I got the gamory one too.
Found out you have to connect by cable and then when on the connect new Co troller screen, click a (not be as I keep getting confused with), and then disconnect, and now use the top right and left bumpers, then it worked
What screen protector people recommend for the OLED?
+1 on the Orzly. Also if you don’t do this already put the screen protector on after you have run the shower. I have no dust under mine as a result. The other thing to note is the protector does not reach across the full width by a few mm. I usually line up the protector on one side and then rotate it down onto the screen. It means my protector is slightly left of centre. It fully covers the display area of the screen so it is more an aesthetic thing than anything else.Orzly
Pretty much all screen protectors are like that. Gives a bit of tolerance otherwise you need to fit them with micrometre precision.Why is it a couple of mm short ?
Does not seem like a quality product
Mine is 1-2mm short in each edge, which it has to be to avoid the screen protector lifting.
