Caporegime
- 8 Jan 2004
- Rutland
On Ocarina of Time the input latency on the Switch is 220ms.
Ouch that's hideous.
You may need to check in from time to time but I play the snes online stuff in the car whilst not connect.As above but you will need to be online to verify you can access them.
Locally but the input lag is as high as if you were streaming
This was my worry. I'm sure there's a large market for an N64 mini!
Presumably it's due to the Switch being underpowered... I heard Wii U emulation was meant to be okay though.
Wonder if Nintendo can 'fix' it.
How can you have a dockable case lolCan anyone recommend a good (childproof) case for an OLED switch? Preferably one that's dockable if possible.
Use a USB extension cable on the dock port.Can anyone recommend a good (childproof) case for an OLED switch? Preferably one that's dockable if possible.
Yeah I've seen the dock usb extension cables, and that would remove the need for the case to be dockable.
Any recommendations for a good case for the OLED model though? These seems to be a few decent ones for the normal switch, but the OLED ones seem thin on the ground
Are they not the same size. I just stuck my oled in the case I had with my original switch
No worries.
switch online + dlc subscription, is that jus animal crossing dlc or any other games ?
Hopefully they add more, as now I've played the few, I'm totally done with the extras. Cost was cheap thankfully, but almost no value to it
Is it true that there's no added functionality with Switch, i.e. browser, Netflix, Prime etc?
N64 games
How? I've not seen itAnd Sega Genesis
