Has anyone used to mobo ai overclocking yet on there asus mobo?
ah the Samsung chip versions. I see the 40/40 ones are hynix. I just missed out last drop![]()
Mine are Samsung IC's
Yeah 40’s are Hynix and the 36’s Samsungs. Holding out for the Samsung ones but they go quick![]()
Mine are the CL40’s and they are Samsung.
Strange , what speed are they? My gigabyte memory support page shows the 40’s being Hynix![]()
The GB support page is wrong, there are a few others like that as well.
F5-6000U4040E16GX2-TZ5RK-G.SKILL International Enterprise Co., Ltd. (gskill.com)
Trident Z5 RGB - DDR5-6000MHz CL40-40-40-76 1.30V - 32GB (2x16GB)
Where does it say Samsung ? Interested as it will make my memory hunting easier if both the 36 and 40’s are the same chips.
Both sets of G.Skill 36's I have are Samsung, just finishing doing a 24h+ burn-in test on the second set now at the rated speeds and timings. No errors thus far, and they aren't getting too hot either.
lol any particular reason you felt the need to run them for 24 hours. What are you burning in? What would you do if the system flipped a bit at the 23-hour mark?
Some screenshots showing coverage elapsed and system info may be useful for others.
It's not my choice, the customer who is taking a test build wanted their system burned in the same manner as the other systems they buy, which means 24 hours on all components, and with new hardware, it is sometimes done 48 hours or as much as a full week.
As I'm sure you are fully aware a system that is not not 100% stable even when realistically run like that maybe 5% if the time is seen as not good enough. When you've worked with commercial, industrial and defence as long as I have you realise the way most people use systems isn't important compared to these settings. NATS wanted a system running for a full 30 days before it could be signed off!
You asked what speed they are, not does it say Samsung.
See my post here and look at CPU-Z - https://forums.overclockers.co.uk/posts/35293938/
So it does, think I will still play it safe and grab the 36’s though as my luck blows![]()
FYI, no system is 100% stable. In fact, it's possible for a stock system to flip a bit at some point. If ran for 48 hours and an error is found, what then?
If data integrity is essential, overclocking the memory probably isn't the best idea! lol
