Permabanned
- 23 Apr 2014
- Hertfordshire
Also, getting a Hub 4.
(Though I dont really have a problem with the hub 3)
I'll switch to Virgin soon I think as it's the only option in my area for 300mb or above.
Is it worth using an affiliate link to get discount? I found a site that reduces price to £37 a month instead of £62 for 500mb.
Name the site!
Meh, cant find an appropriate PSU anywhere/not sure what to get, will have to wait 2 weeks for VM to send a PSU out.![]()
Its pretty standard - it needs to be the same polarity on the barrel connector, same output voltage and be capable of equal or greater amps.
I beg someone to shed some light. The last maybe 2 months or so I’ve had serious drop outs and ping spikes 300ms for a few seconds and drops back to 30s. It’s also flashing errors when playing games for packet loss etc. I’ve changed the cable had an engineer out he’s changed my hub 3 to a hub 4 also.
It’s making gaming unplayable (ps5) , I’m led to believe there is only 3 of us in the green cabinet and there engineers say it all looks okay, where do I stand and what could it be or am I screwed?
The issue also is I do get the download speed so when I contact them they just think it’s all okay which it isn’t. I’m getting 350mb down and between 10-20 up
Lastly they’ve got me by the balls as I can’t get any other provider to my house or I’d leave.
My router is 2 ft away from my ps5 and yes it’s hard wired it’s most definitely noticeable on the PS5 yes. I’ve also tried it using 5ghz wireless to see if maybe the Ethernet port or various other cables were defective and the same packet loss spikes are there. The virgin engineer last week even gave me a couple of brand new cables to use. I’ve not used BQM as I don’t have a computer to run it, I have however used an iOS app called ping plotter and it’s showing the spikes every other second this is wireless however but still way more than it should be.So you have latency spikes, are you running BQM and if so does it show corresponding spikes? Is it only obvious on the PS5 and is it wired or wireless - I know you mention cable, but the last time I took that for granted the op lead us all on a wild goose chase for multiple posts till they clarified they were using power line![]()
Was about to come back and say it’s not working, been around 10 mins with nothing showingBQM will work fine, it just uses your external IP. Give it a good few hours to start recording results.
For the life of me i just cannot get my Superhub to give ANY internet while in Modem Only mode (Yes i connected ethernet cable to the only active slot 1)![]()
Oh really, Sure i read that its Port 1 that's active during Modem only mode, Il have to switch it to Slot 4Not sure which slot it "should" be in but mine is in yellow slot 4 on my SH3, connected to my router.
