Did they not even attempt to drop you back down to m500, for now, to see if that resolved it? Would be very surprised if the Hub 3 is borked.
Thanks for the info. I should get getting my SH5 tomorrow. I take it here is nothing even loosely related to QoS in the settings then?
My Superhub 5 arrived late last night, so I installed it today. Despite some multiple contradictory texts from VM's automated service to provision the hub onto the Docsis 3.1 network, it was pretty straight forward. From a quick look around the UI, it seems it's a more capable bit of kit than my SH3, with many more network options and some useful diagnostic stuff. Some of the obvious ones (such as selecting your own DNS servers) seem to be missing, as VM obviously don't want you changing those. The UI is the same sort of open, lightweight pastel style, and the firmware still labelled itself as a SH3 until the first firmware update.
It's a nice bit of kit, the UI is still a little clunky, and it still seems to be early in it's development eg. one of the reasons it's not being offered to 1 gig customers is the pods/boosters that you get for free on that tier don't yet work with the SH5, and neither do some of the VM apps. It's physically slimmer, but also taller, and is a perforated black box with a grey fabric front and a very subtle status light that shines from the corner and leaves a little spot of light on the surface in front of it.
It's a few years newer, gets away from the Puma chipsets, and better than previous hardware, though the firmware/software probably still needs a little refining. It's probably more than enough for the average user to use it as a router, though high end users will stick it in modem mode and connect a dedicated router to get more functionality, and take advantage of the 2.5 gb port on a 1 gb or higher tier by upgrading after you get hold of a SH5.
Can we see BQM graph for this.?
Virgin Media have never called anybody back in the history of telephones, it's a tactic to get you off the call
Well, I ordered a universal ac adapter from Amazon and it came today, was a punt because wasn't sure any of the 14 adapters would fit but one did. Now up and running with the Hub4, though its certainly nowhere near Gig download speeds at the moment. Getting near 50 up but only 400 down. Will let it settle and see how it goes.
Your cooling off period starts from the day they finally activate you, so just stick with your current provider and then cancel Virgin in the cooling off period - at least this way you get the cabling installed which is the bit they seem to struggle with.
I got the 8gb Sim from Uswitch on the 25th Nov, still not received either double data or broadband speed increase. Spoke to VM yesterday and was told my broadband speed bump should happen when I get my SH5 tomorrow. So we shall see. Not spoke to O2 yet regarding the double data as tbh 15gb is more than enough for me but will happily take 30gb if I can get it![]()
