3800 CL14Can anyone confirm if this RAM can do 3600 CL14?
1337
https://forums.overclockers.co.uk/posts/35303699/
Isn’t that 3600?
In case anyone doesn't know, great sales on RAM. 3600 32GB kit can be had for £158.99: https://www.overclockers.co.uk/team...00c16-3600mhz-dual-channel-kit-my-002-8p.html
If you are in the market for 32GB of DDR4 no reason to not buy now. I know technically the Crucial kit is £128.99 but to guarantee dual rank for £30 plus slightly better XMP timings seems worth it.
Isn’t that 3600?
also, can you try tRASat 21 and see if it’s stable?
I take is tRAS to CAS isn’t happy at 14? tRAS to CAS has the biggest impact on your performance.
Is this kit of RAM single rank or dual rank?
I have some 32gig dual rank Samsung modules that are at 3200 CL 14-15-14-14-21 at 1.35v.
If I try get the kit to anything like 3266 or above, it won’t POST. Even at 1.5v. Very odd.
tRAS on B-Die can go down to 22 - voltage affects this ability though so reduce slowly and carefully. Pay careful attention to post and boot times, you should "feel" when this becomes unstable and move back up if so.
tRC = tRAS + tRP so a reduction in tRAS and tRP can reduce tRC. You don't need to test this, calculation will suffice.
Works but benefits are minimal, if any
I think you're looking at an old AIDA screenshot when I was on A.86 AGESA 1.2.0.0.Unless I missed something hasn't your L3 Cache speeds almost doubled for read and big boost to write and copy?
1.5 ok?
Got them at 3800 16/16/16/38 1t 1.4v atm
Have you tried 3800 1900FCLK CL14 1.5V?I had to bump mine to 1.450v (bios reads 1.472v or something) at 3600 CL14 with DRAM calc fast timing to get the system fully stable.
Am I tripping or were the Team Group 3600 CL16 32GB £159 yesterday? I'm pretty certain they were so went to check compatibility with someone to ensure thats what they wanted and now it appears they have gone up £40?
Gutted if I have missed out on this deal![]()
Yeah they were that price since the 25th Nov.
Push until there are errors, then drop back if there arei haven’t! I’m pretty content with 3600 CL14 with tightened timings tbh, don’t want to push it too far!
is 3800 likely to work with a 3700X?
I currently have the Ballistix running at 3733 16,16,20,20
Would there be any noticeable difference in gaming if I were to swap to the 8 pack and hopefully tune to 3800 CL14/16 (assuming it would clock to that)
Not worth the money. The only time something like the 8 Pack makes sense (upgrade wise) is if you have say 16GB of <3200C16 and you're looking for 32GB while making sure you get dual rank as an added bonus. This made some sense at £158.99 but at current prices I'd definitely stick to what you have now.
That's fair enough, I wasn't sure if the ability for tighter timings would have been a much bigger benefit but I guess not.
Perhaps I should just try and tighten the timings a bit further with what I have then consider the swap if they drop in price again.
Maybe a small increase in minimum fps if you game at 1080p with low/medium settings. Good idea, trying tightening timings with your current set - 3800 / 1900FCLK / CL16 might be possible
