Post Your Home Cine & HiFi Kit...
My system before and after we moved into our new place, a bit simple compared to most:
65 inch Samsung QN95A
Sonos Arc
2 x Sonos One's as rears (but not shown).
I like it, sounds great too and a big odd shaped room of about 60m
Sorted the cables on the floor after I took this pic, but not home for a few weeks now :(
uc
uc
Watching Dune 2021 and I can confirm, the lows are pretty darn epic!
https://images.app.goo.gl/VP61bsjZtpTVTu7e9
https://images.app.goo.gl/8TPxU4B4hjfLZsYY8
Looks good. I'm sure I've asked the question before (and you've told me!) but where are the speaker stands from? I think you mentioned they were some other type of furniture reimagined.
Im finally getting my setup back next month after 8 months of renovating the new house, and these would go nicely with my oak style floor.
Thanks. Good luck.
They're stools I bought from Amazon with modded tops.
https://www.amazon.co.uk/dp/B01BQCC...abc_PH2PYYE6EE7PT38Q66WV?_encoding=UTF8&psc=1
Before with no base on the stands
uc
I made up some bases with plywood.
Topped them off with isolation foam and 5 deg tilt.
uc
uc
Oops. Here you go.
Premier Housewares Bamboo Kitchen Stool Wooden Bar Stool Round Kitchen Stools Bar Stools Bar Stool Stool Chair Wooden Stool White 43H x 30W x 30D cm https://smile.amazon.co.uk/dp/B01BQ...t_i_RNHZR07PNTHHRBJZK1PX?_encoding=UTF8&psc=1
Cheers, looks good! Just need to find some isolation foam and I've got some spare plywood. Why.
Forgive me for a dumb question but what is the isolation foam for? /where best to get it from?
Presumably to improve acoustics/stop resonance in the stand?
Thanks. I cut the below to size.
Anpro 2 Pieces Studio Monitor Acoustic Isolation Pads, Stabilizer Speaker base, 12“x 7”x 1.5“/ 30cm x 17cm x 3.5cm(Black) https://smile.amazon.co.uk/dp/B07D5...t_i_AHJMFA8Q9VSFQ6AV7ACC?_encoding=UTF8&psc=1
In my case the foam was used to raise the speaker height and project the tweeters to ear level. I also just like the angled look.
Cheers!
Apologies for all the questions. Did you also have screw slots/attachment bolts /similar on the bottom of your speakers or are you just hoping they're not knocked over?
