Posted this in Images of items I have purchased (except trainers)
Tidied cables up and double checked settings of cart/tonearm.
The cable KEF supply (RJ45) to connect speakers together is comically short. Used a spare 5m I had spare and tucked them down the inside of the stands.
Had plenty of turntables over the years and modified a few of them, but this Rega is on another level and it's my first Rega too. Been told the Apheta 3 needs 50-100 hours to break in before it opens up, sounds great at the mo to be fair!
Looks great, good choices.
Do you feel the TV is a a little too high up on the wall?
My setup looks low in comparison
Thanks!
That was a question of great debate during lockdown last year when we got that tv with her indoors.
It's a Samsung 65" 'The Frame' Qled screen. We sit just over 4m away from it and being it emulates a picture frame (when on standby) we didn't want it sitting too low on the wall, nor did we want our necks straining looking up. Especially after our previous tv (pictured below) was mounted high, not ideal and definitely not wanting that neck strain inducing height again.
Are they Klipsch The Fives in your setup? How are they? I shortlisted those too.
Very clean looking layout you have there, I like it
An optical illusion I think. The sofa is low, and so is the top of the wall the TV is mounted on. No neck ache problems when gaming for hours..Maybe it's the angle, but that TV looks crazy-high.
a lot of people on here seem to like having they TV put high. I thought eye level was best (in the same way as you would view a monitor)?
According to link below, ideal height of centre of 55" is 56" (140cm) from the floor. Just measured, and mid point of screen is 135cm from the floor - so ironically it's slightly too low...An optical illusion I think. The sofa is low, and so is the top of the wall the TV is mounted on. No neck ache problems when gaming for hours..
Yep - I got a vent put in, and then with some pvc tube to a fan mount - dual 120mm acinfinity fans controlled by the matching fan controller/thermostat thing. Good thing too as it hits 30 Deg C at times.Pretty sure I copied you from a post on here or avforums when we built our house, n thought I'm gonna stick all my gear up there too. Works well, all cat6/speaker cables for all rooms etc all end up there so nice n tidy, but **** me it's hot up there craning my neck trying to get things reconnected!
Here's mine right now, don't think I've posted it in here before.
Kit list includes Anthem AVM60, Epson TW9400, Nakamichi AVP1 amp,2x Crown XLS1002 amps, XTZ Cinema M6 front LCR, S5 surround and backs, S2 front height and middle ceiling speakers, 2 x 12.17 subs fed via a MiniDSP 2x4HD. Think thats the lot in here. Sounds great
Following on from this...
Covid ruined real chances to go out and listen to replacement speakers, but the few shops I did visit actually really let me down in terms of customer service and just letting me listen to some systems. One put me on the shop floor then told me to not turn it up too much.. ok m9.
So eBay to the rescue - I decided to find look for Dali's of similar vintage to mine in attempt to get a matching centre speaker as a minimum. Well I haven't quite succeeded but I found a set of Dali Ikon MK1 speakers (centre + LR) from a guy doing an upgrade.
The centre is a little bit smaller than I had realised, and is a slightly different grey finish on the front. But thwe wood finishes match, so it still looks decent and sounds really good too.
The bookshelf speakers will find their way into my office and be powered by a Sonos amp but I gave them a chance via the Marantz in the living room for two films and I was pleasantly surprised at the bass response and general sound quality. So much so that it had me rethinking floor standers in my living room... until I wanted more volume and the audio became a little bit more complex, then I remembered I'm very much a floor stander kinda guy
Anyway today I spent this afternoon routing some cabling (including running a couple of cable pullers so I can run a new HDMI to my projector to support 4K HDR at some point), mounting the TV on the wall and having a general tidy of my kit into a corner unit I got for free from a neighbour.
Aside from the centre looking a bit small, I'm really happy with how it looks now. Rears and Atmos next on the list, and if a larger centre comes up that matches - even better !
Thanks for looking
