50% increase, great.
Tax rises, energy costs through the roof, fuel prices and the no doubt incoming council tax raises. There’s nothing quite like getting bent over.
My DD was cancelled (in error) as UtilityPoint crashed and burned so I ended up moving to EDF on their Welcome tarrif that requires me to pay by card each month. Obviously I'd like to get the DD back up and running but they can't deal with me on the phones yet. Online I get the option to swap to this:
Electricity
Annual estimate
£1,592.37
Daily standing charge
24.04p
Unit Rate (pence kWh)
21.56p
Gas
Annual estimate
£1,042.11
26.12p
Unit rate (pence kWh)
4.053p
Just had an email from Bulb, they want to up my DD from £65 to £127. The lowest they will let me change it to is £111. I have 0 balance, just always pay the £65 and top up if required. Last month I had to add in about £20. I cba with having my money sat on a balance for no reason.
My usage in 2 bed flat, Electric only.
Aug 450.8 kWh
Sept 295.2 kWh
Oct 241.9 kWh
Nov 395.0 kWh
Been on OVO and I can do a 12mth fix for £111pm. I am half tempted I have to admit.
That is the cap price, so you should change to it if your current one isn't a fixed deal past April.
April the cap will go up a lot, maybe 40-50%, but you are unlikely to get a better deal than the cap. Hopefully prices will settle down toward the end of the year if supply ramps up and new cheaper fixes start again.
1382 kWh * 3 (to get 12 months) is 4146 kWh per year, which isn't bad considering you're only using electric. But then you have to remember those readings are from a time of year when usage is starting to creep up, due to lights being on longer and increasing demand for heating towards winter.Just had an email from Bulb, they want to up my DD from £65 to £127. The lowest they will let me change it to is £111. I have 0 balance, just always pay the £65 and top up if required. Last month I had to add in about £20. I cba with having my money sat on a balance for no reason.
Aug 450.8 kWh
Sept 295.2 kWh
Oct 241.9 kWh
Nov 395.0 kWh
Yeah I think your right. Sadly I can't drop it down.£65 is too low, £127 is too high. £80-90 would be about right for your usage.
Cheers for checking on your end. I moved to bulb in August (when I moved to the property)1382 kWh * 3 (to get 12 months) is 4146 kWh per year, which isn't bad considering you're only using electric. But then you have to remember those readings are from a time of year when usage is starting to creep up, due to lights being on longer and increasing demand for heating towards winter.
I have a spreadsheet with EDF's Standard Variable tariff and with 4146 kWh and it tells me that's nearly £80/pcm. As @200sols says, £90 would be a good amount to set your direct debit to.
Have you just moved to Bulb? If so, perhaps they will just need to see your usage over a longer period, before their calculations will give you a more realistic figure to set your direct debit to. Ride it out and pay what they ask. If you're right, you might be in for a refund in the middle of summer.
Tell them you want to go on variable payments. That way you pay for what you use.Just had an email from Bulb, they want to up my DD from £65 to £127. The lowest they will let me change it to is £111. I have 0 balance, just always pay the £65 and top up if required. Last month I had to add in about £20. I cba with having my money sat on a balance for no reason.
Aug 450.8 kWh
Sept 295.2 kWh
Oct 241.9 kWh
Nov 395.0 kWh
We did a 2 Year fix in September with Eon Next but we’re in the process of buying/selling and it appears you can’t take your tariff with you so It looks like we’ll be paying a lot more once we move.
We were stiffed by this too. Pretty much a doubling in costs overnight. At least they were kind enough to let us leave penalty free.![]()
I’ve had similar, paying £38 a month now but used £49 and they want to put my DD up to £119, lowest it’ll let me set it to is £101.45, they tried this when the news came that they were struggling to keep afloat.Just had an email from Bulb, they want to up my DD from £65 to £127. The lowest they will let me change it to is £111. I have 0 balance, just always pay the £65 and top up if required. Last month I had to add in about £20. I cba with having my money sat on a balance for no reason.
Aug 450.8 kWh
Sept 295.2 kWh
Oct 241.9 kWh
Nov 395.0 kWh
Just remember when things do get better, these prices will remain.50% increase, great.
Are they even getting help though? Like my household can handle the rise, im not happy with it but I can absorb the increase, but if poor households were already suffering what little hope is there that they can ride this through winter.Someone has to pay for this. The poorest will get help while everyone else's bills will go up further
Its a global issue though, so were all ****** basically. Iv heard the nordics are basically getting shafted not twice but three times, so it could be worse....I guess.
