I've tried different resolutions and I have not noticed any difference.It's like it stuck at 720p.
I haven't tried HL:Alyx or star wars squadrons to see what I think yet.
Think I will try the Fibre cable to see if it helps.
120hz using more battery makes sense.
Yes,I have set the IPD to 3,which has made a difference to some extent.
If I could just get windows looking better and cut out the blur a bit, in general,I would be very impressed with the Quest 2.
Loving the VR experience so far despite the above issue!
What games have you tried?
You really need to measure your IPD, its not that hard, there are even phone apps that will do it. You just might be unlucky and have a really large IPD (70+)
I'm not using a 2070,I'm using my laptops 3080 16gb.
Oh, I forgot. Sorry. Even still, the 3080 in a laptop is nowhere close to the desktop model in performance. The laptop 3080 doesn't even reach the same performance as the desktop 3070. It's still faster than your desktop 2070 though. But it's not powerful enough to run the max render resolution.
 Good stuff.
