Entry level Alder Lake: i5-12400 review, the new value king
28 May 2007
Comparing actual power draw of one part to TDP of another.
There's also heat density to consider.
The 12900k is turned up to 11 and difficult/expensive to keep cool in full core workloads....but fine for gaming.
The rest of the stack has been doing fine with cooling in general.
Yeah. 150 watt is 45 watts more than 105 watts. That’s the heat load placed on the cooling element to dissipate.
20 Aug 2019
SW Florida
The T parts are potentially looking really promising. 12700T at 35watt and H670 should offer some very impressive performance per watt figures.
Looks like Intel is already doing well without the T parts:
20 Aug 2019
SW Florida
Again, 150 watts is 45 watts more than 105 watts.
Great. You can do math with two unrelated numbers.
TDP and actual power draw are two different numbers. You know this, but I suspect you really just need to distract from direct comparisons of performance here, and thus persevere.
28 May 2007
151 watts is what the part pulled. You need a cooler that can at least dissipate that. If that’s on the moon inside or out, it’s still 151 watts.
Hope that clears up any confusion.
20 Aug 2019
SW Florida
And AMD's parts pull more than their TDP too.
Heck, the wraith cooler from my "105w" 3800X was unable to cool my "105w" 5800X. TDP is NOT power draw.
I hope this clears up any confusion.
