Enable ReBar and try a selective start-up too. That means you disable all non Windows start-up apps and services.No, am not using that although I have not turned hardware accelerator off in battle net launcher AFAIK I'll check that soon
To reboot in a selective startup:
Press WINDOWS-R on the keyboard to bring up the Run window, enter MSCONFIG and click OK.
Under the General tab, click "Normal startup" if it is not selected already.
Under the Services tab, put a check on "Hide All Microsoft Services" and then click "Disable All."
Under the Startup tab, these will still be disabled in Windows 10 in the Task Manager.
Click OK on the MSCONFIG window, and then click Restart when prompted.
