- 27 Mar 2013
Have you not seen the cost of leccy compared to gasGas hobs are cheaper to run, but they are not that much cheaper, certainly not for spending a load of money to swap it.
.Have you not seen the cost of leccy compared to gasGas hobs are cheaper to run, but they are not that much cheaper, certainly not for spending a load of money to swap it.
.Half the heat from gas misses the pan anywayHave you not seen the cost of leccy compared to gas.
Yeah, not a fan of electric hobs. We had one like 30 years ago. Looks cool, but it just ain’t the same.Food tastes and cook better with flame...
Not electric...
Electric hobs need to be banned!
Kind of want to go all electric in the house in the next decade or so, but I think the gas may need to stay just for the hob![]()
I’m not sure what your getting at?
It sounds like you haven’t been paying enough to keep up with how much you have consumed, hence the sharp increase to recover that position. You’ll be able to reduce it once it is.
Haha. That sounds good, but I won’t be going that far. We did a bit of food growing in our garden a few years back before we got dogs. The amount of work that goes into and the results you get back, could have spent the money buying from supermarket. Lol. Was a fun experience though.Friend of mine is totally off grid but loves cooking on gas, so he has a hob that runs on LPG/Calor. No need for mains gas supply and standing charges etc. He's also got his own water/well and pretty much grows most of his own food. Still buys meat though.![]()
Surely you just use a bigger panHalf the heat from gas misses the pan anyway
. I've not dibe the maths but I'm sure electric hobs uses loads of electric and they are normally very slow to respond as essentially they're just a hot plate (not talking about induction here).Heat still goes around it.Surely you just use a bigger pan. I've not dibe the maths but I'm sure electric hobs uses loads of electric and they are normally very slow to respond as essentially they're just a hot plate (not talking about induction here).
They are all 100% efficient at turning fuel into heat. Do you mean energy transfer to food?
That’s literally what I said earlier. I still don’t see how gas is better than electric for that like the link posted suggested.Yes, put your hand near a gas burner you’ll quickly realise a lot of heat is lost directly to the air from the burner itself and never makes it into the pot/pan/heated item. Hence it’s less efficient.
Being pedantic I’d dispute the 100% efficient as energy is lost to light on all forms (except induction?).
I think using electricity for heat is barbaricconversion to heat energy is nigh on 100%
About efficiency not cooking. Wow this is going around a bit. Anyway I guess the gas hob waste heat heats the kitchen too anywayIt isn't, just personal preference. I used to think gas was better but then I used an electric hob that was from this century, it's also a lot easier to clean an electric hob, hated the faff with the gas hob.
