What deltas do you see before and after LM?With a bit of light MPT I've broken my previous record and I`m on just over 19700 now with timespy (just over 22000 gpu score) thats with the last recommended drivers which are from last Nov I think. The CPU score prob lets me down a bit over the 59xx users although if I push an OC on that might meet that 20000+ target.
So I reckon with a bit more fight I could break the 20000.
Liquid metal has probably made the difference too.
That's a pretty good result then from where it was. Can't really hope for much better than that.I cant quite remember what its called but it dropped 20c, its the middle one in my OSD, the hotspot I think it used to get 108c - 110c and now it maxes at 88c in Timespy. With the OC shenanigans above it was 98c.
I think I posted it earlier somewhere in this thread.
That's a pretty good result then from where it was. Can't really hope for much better than that.![]()
That has not been my experience. I get marginally better FPS in full screen mode. Can you provide some more context, examples etc?@LtMatt - any idea why borderless fullscreen works so much better than exclusive fullscreen on the 6900XT?
I think most cards that have coil whine usually get better over time.Does the coil whine on these cards quieten down over time? My card sometimes sounds like an old mechanical hard drive!
Yes, my card whines line a banshee at thousands of FPS in the menu screens for Far Cry 6/Forza Horizon 5. It's fine in games though where the FPS at 60-200 etc.Also depends on what you are doing. Some menu's in games make the FPS go crazy so the card produces coil whine. I mainly limit my FPS to the same hz figure as my monitor refresh rate to stop it.
It does seem to do it worst in menus. I mostly play Escape from Tarkov, coil whine doesn't seem to bad in the menus or in game but when you're in your hideout, it screams!Yes, my card whines line a banshee at thousands of FPS in the menu screens for Far Cry 6/Forza Horizon 5. It's fine in games though where the FPS at 60-200 etc.
Goes up to 144. EFT is one of those weird games where the GPU can typically run at below 80% util, jump around between 1100-1800MHz and get 90fps at ultrawide 1440p.When it screams what is your FPS ?
Could be, 850W is the recommended minimum. That's for a 6900 XTX, 255W stock power limit.
With an XTXH, with higher voltage and power limits, three PCI-E connectors, I'd recommend 1000W Platinum PSU at a minimum, which is what I use.
My 6900 XT has 3 connectors and runs fine on my Corsair SFX 750w PSU.It does depend on the quality of the PSU though my 850W SF platinum doesn't complain with my 350W 3090 but 3 PCI-E connectors, that would be a killer right there it simply doesn't have a spare
That's true mate, a high spec PSU can definitely help with edge cases.It does depend on the quality of the PSU though my 850W SF platinum doesn't complain with my 350W 3090 but 3 PCI-E connectors, that would be a killer right there it simply doesn't have a spare
Yeah, for a while I had 2 cables with the third plugged in from a pigtail. But I’ve not got 3 single Corsair cables all plugged into the PSU->GPU. No issues so far.Do you have 3 plugged in, only asking cause I'm looking at getting that PSU and would like to not have to worry about power hungry GPUs.
