- 14 Oct 2007
- newcastle
No it doesn’t, if it’s been powered on it’s usedTested for sub 1min prob still counts as new
It’s illegal to sell something as new when it’s been used
Yes a manufacturer can test an item, but a retailer can’t and then sell that item as new, which is what has most likely happened here, what your saying is like walking into Currys and buying a breadmaker for them to tell you “BTW we’ve tested it to make sure it makes bread ok” but it ok, it’s still new because we have only cooked 1 loaf of breadTesting is not using. Look up the law
Doesn’t explain the pin marks on the bottom of the chip
I've also had tray CPU's that looked exactly like this (including the underside) brand new fresh out of the factory. I would wager that it never got tested or even used at ocuk and that they are just pulling them out of a tray and sticking them in a box. To me it looks exactly like your typical OEM tray cpu.Doesn’t explain the pin marks on the bottom of the chip
I am clearly not seeing what you are seeing. With the top of the chip how many coolers have you pulled off that leave a perfect grid patternI've also had tray CPU's that looked exactly like this (including the underside) brand new fresh out of the factory. I would wager that it never got tested or even used at ocuk and that they are just pulling them out of a tray and sticking them in a box. To me it looks exactly like your typical OEM tray cpu.
I can't see what you mean? What marks?![]()
if you look on the second picture he posted of the bottom of the chip, you can seen the pin indentations in the centre of the pads
Hang on, LGA sockets don't have pins in the traditional sense. The "pins" are flat springy copper things and not actually spiky. So how would a flat springy non-spiky copper thing apply enough force to indent a flat copper surface on the CPU?you can seen the pin indentations in the centre of the pads
Had a bent pin in my ITX board and recently started getting some weirdness so popped the CPU out to see if that pin was OK. Can't say I saw any indentations in the CPU and it's been installed for many years.
I can see the indentation marks on most of those pads
I suppose an indentation is maybe the wrong term, it’s more like a scratch that’s left as the chip is compressed into the socketI don't think you can, what you can see is an amount of corrosion where the pads were not touching the pins. if I cleaned it with ipa you wouldn't see a thing i'm fairly sure of that. Interesting but i'm fairly sure the socket will not have enough pressure to damage the cpu pads with indents.
Mate have look at the link, I have circled the pads it’s really evident on, on your picture, you can see a hairline scratch in the middle of the pads I have circledMy eyes arent nearly good enough for this... im sitting here squinting at a chip
I won't lie I've had tray cpu's from intel that still had some paste on them so honestly I wouldn't be that surprised either way. I guess they may pull a few from a try to make sure they make the grade?!
at least not on the top half of the chip I cleaned up with IPA - Still see em on the bottom half though. Wonder what Intel policy on a tray would be in terms of a test?I’m sure Intel testing them is fine, it’s if retailers are testing them, that’s the problemI see em - Although after a quick IPA I now cannot see emat least not on the top half of the chip I cleaned up with IPA - Still see em on the bottom half though. Wonder what Intel policy on a tray would be in terms of a test?
