A carrier is slow (in a per second rate) in both speed and change of speed/direction. We're talking >1mile for a turn.
Still can make some pretty impressive turns though
https://youtu.be/ziCvqZIyjto?t=63
With all the equipment Russia has pointed toward the Black Sea, I think they'd have a pretty good chance of hitting something there.
What's the mood of the thread/forum? Should we be getting involved or not?
Probably a better way to answer this:
An aircraft carrier radar : 250 nmi (460 km)
MACH 8 = 2,700+m/sec
So the 460/2.7 = 170 seconds from the outer limit of detection. 3 minutes. Most US carrier groups have an eye in the sky, so it would be longer with the AWACs (if the plane is between the launch and the carrier you could get 800km for example).
A carrier, say 56km/h top speed, means 15.5m/sec max, or in the 3 minutes 2,790m. That's a maximum angle of tan-1(2790/460000) = 0.3475 degrees at full range. Assuming a 90 degree angle attack to the carrier.
So MACH9, turning radius is 190 miles (305.77km) at 3g max (given our missile is liquid propellant) or 305770m/360 *0.3475 = 295.15m distance to perform a maximum angle deflection at 3g. Or the last 295/2700= 0.109 seconds of flight time. The ship may have moved 1.55m forward in that last 0.1 seconds.
So I suspect it would (technically) be able to hit a carrier, given the carrier is 40m-76m beam (ie the narrowest target).
3 minutes is a long time for a sensor package to remain on target, with noise from countermeasures.
I read somewhere they are accurate to within 7 metres and I'm assuming thats not a moving targetThink cruise missile at MACH 5+. There is also a concept of reusing ballistic missiles with conventional re-entry warheads as a ship missile - especially against larger ships and subs.
yea and look how much he got away with....Can you imagine the Russian media going after Putin about the levels of corruption or sleaze over there. No, because reporters that do end up in a body bag after killing themselves jumping from their balcony and shooting themselves on the way down.
Here, the government are held to account when they do stupid things. Which they do, a lot. As it should be! If the news was state controlled do you think they'd be getting such a hard time?
hypersonic weapons that is
That's how Reagan and Chernenko sorted it out back in the 80's at the end of the Cold War.Sort it out with a good old fashioned scrap.
President of Russia v Mayor of Kiev. Live on Sky box office.
Now everything looks like a tank!
rockets.
The [blast] kill mechanism against living targets is unique—and unpleasant. ... What kills is the pressure wave, and more importantly, the subsequent rarefaction [vacuum], which ruptures the lungs. ... If the fuel deflagrates but does not detonate, victims will be severely burned and will probably also inhale the burning fuel. Since the most common FAE fuels, ethylene oxide and propylene oxide, are highly toxic, undetonated FAE should prove as lethal to personnel caught within the cloud as with most chemical agents.
are tanks even the main worry.
wouldn't artillery be the main problem and rockets.
isn't that russian tactics? blap the area they want to take, enemy withdraws and Russia moves in.
rinse and repeat until you've conquered a waste land
Very hard to control any battle without air unless heavily urbanised and even that depends on the enemies views on collateral damage.air is the main worry because ukraine has none
The latest 2020 Harpoon anti ship missile variant is MACH <0.7
