- 13 Jul 2004
- Stanley Hotel, Colorado
Will the cable standard required be higher or same as USB C
That's the thing, within the USB-C connector format scope there are dozens of individual standards, USB 3.1, USB 3.0, USB 3.2, even USB 2.0 is a standard for USB-C. Then you have Gen 1, gen 2 within them, then you have e marked cables that support PPS which is a more recent standard by the USB-IF for faster charging with less heat and better battery wear, then you have cables that support QuickCHarge (of which there are many versions), then you have cables that have Quick Charge but don't have PPS and a whole bunch more.
You can get cables that support everything in one, but they are usually extremely short cables useful only for laptops or devices that are right next to each other, and they are expensive too.
Putting my 55" on the wall was the single most terrifying moment of my life! I had to have a drink afterwards![]()
So the intro of USB4 will be nothing like the intro of USB Type C because they will be cross compatible? (Unlike Micro USB to USB C)
That hasn't been true for HDMI for a long while. Nor phone charger plugs.Yes and no. I'm with kona786. Having so many standards with the same connector is a disaster not a plus point. Before you either had the right connector or you didnt and the only thing you had to worry about was some cables were charge only and not data as well.
Now you may have it lead that fits but it might not support the protocol you want.
No drivingProbably as it was on clearance. I wouldn't pay £350 for it so it really doesn't matter. It has all the important features from filters, room size that i want, app control that works and it's really quiet. It's practically next to my bed and i can't hear it.
NahAll gone! Did you get one?
It might turn up again i can't belive how quick it wentThat actually showed up on Argos too later the same day but it was out of stock.
