Man of Honour
- 5 Jun 2003
- Falling...
I am progressing
My first 3 tracked workouts total lifted where
3rd jan Push 4500kg
5th jan Pull 4700kg
7th jan Legs 3700kg
Last 3 recored
28th feb Push 5500kg
2nd mar Pull 7800kg
4th mar Legs 6300kg
I started mid August. Time is the main thing. I am rushing sets some days so I can be finished or cutting rest between sets and would rather be able to take my time. I'm going to try the above for a few months and see how it goes.
that's why I suggested maybe look at shorter sessions with less in them. Perhaps do a 6 week cycle with some exercises, then the next 6 week cycle rotate some of the exercises, i.e. instead of doing pull ups, do lat pull downs, instead of DB rows, do cable rows etc...
does that make sense? 6 weeks is a good adaptation period for exercise, changing it at that point does help punch through plateaus a little, especially if you are keeping the core lifts the same, you can then use the support exercises as a way of keeping it fresh. The core exercises you could then change their intensity / volume to suit.
However, I hope you get what I mean?
