Not knocking him, but it's well known people pad out their videos to put ad breaks in and generate revenue.
Can't disagree there
5l is great, thanks - I wonder if I am asking the right Q though. Is Quick Detailer the best "spot cleaner" for things like bird poo etc?
You can get dedicated PPF shampoo which essentially has some fall out remover within it, I assume PPF being softer than clear coat can leave it susceptible to having iron road deposits embedding into it.
I'm not sure polishing PPF is a good idea seeing as polish is an abrasive for removing microns of harder clear coat, and again PPF is soft. There are PPF coatings which I assume are designed to adhere to the softer and more flexible PPF surface.
I would look up the PPF manufacturer and follow their maintenance guidelines. Some of these PPFs have self-healing abilities and you wouldn't want clay and polish to risk that.
Other half has scraped the side of the car with a few stray twigs from some hedges she said, I can’t really feel the scratches (2) with my finger nail but it doesn’t look great and literally goes down both doors. Any ideas what I should use to maybe try buff it out ?
Oh so it IS that?!Well it's orange outside now so I hope everybody is prepared for their cars to be covered in Saharan dust!
What did you use to clean the engine bay ? Did you cover up anything ?
