Caporegime
- 18 Oct 2002
Prime doesn't use AVX 2, does it? If you run OCCT test for AVX 2 units, it can only find issues with these units (and connected systems) and no other parts of the CPU. It's best to run that and then standard tests too - it has variety of tests, after all.
Agreed, thought it tested whole sys. Was a ram issue anyhow, my B-die doesn't seem to like anything over 1.45v (well vented sys so heat isn't the problem).
