Tiny Tina's Wonderlands ! - Borderlands spin-off
No, guns are left click as usual, it's F to cast spells.
bad wording with "at the same time" I mean I'm using them together, and not solely one type.
After a few hours I'd say it's really rather good !!! Chose a 'Graveborn' and keep sort of killing myself with Dire Sacrifice :cry:
How does that actually work then? Like BioShock 2 where you have spells on left trigger and guns on right trigger?
Gun is bound to the mouse and spells to the keyboard. I'm currently limited to two, bound to F and G. Hopefully more will open up later.
I've been playing this for about 3-4 hours now and tbh, I'm very much enjoying it! Definitely far more than I did BL3.
In terms of where I rank this game in the short time I've played it, I would put it 3rd behind BL2 & Tiny Tina's Assault on Dragon Keep.
I went with Sporewarden with the aim of mixing into Graveward later on.
I'm enjoying the game but quite disappointed at the performance.
It certainly stutters less than borderlands 3 but I notice there's an "optimizing shaders" message at start up which I've never seen on borderlands 3.
But I got to a point in the game and I'm running at about 40fps on a 3090. It just doesn't feel right, at no point in Borderlands 3 did my fps go that low.
Hopefully future patches will sort it.
FH5 optimises shaders at the start as well. I haven't noticed any major stutter but then again I haven't ran MSI Afterburner to check FPS or frame time.
You need to be running the latest nvidia drivers. My friend has exactly the same issue with his 3080ti. He fixed it by updating the drivers.
Is everyone playing this alone or does anyone want to team up? I'm level 23 right now but would enjoy playing it as part of a group if anyone's up for it.
I'm only on level 10 or something. I'm at the part where you meet Torgue and severely underleveled so need to do some sidequests. I've actually been having fun hunting down the lucky dice in Brighthoof; in which vein, how do I get back to the very starting area because I missed most of them?
You can go back by going through the transition area to Snoring Valley, from there use the fast travel to get to the start.
more codes ;- https://shift.gearboxsoftware.com/rewards
Skeleton Key Expires: April 8 BTX3T-6RTWZ-K5BW5-3BBB3-3TFCZ
Skeleton Key Expires: April 7 BTFTB-RSJKZ-WWB5C-T3JJT-BS36S
Skeleton Key Expires: April 7 TB6BT-SWJCS-WKTK5-3B3B3-5BJW9
Sometimes they still work, but expired
Skeleton Key Expires: March 27 B36T3-KSZ6F-K5TKK-JJ3B3-B6B3J
Skeleton Key Expires: March 31 JBRTT-BZH6F-CC3W5-3TTTB-XB9HH
