- 15 May 2012
- Louth, lincs
Anyone know how well the 9900KS were binned?? No wonder stock is not an issue with the KS variant, looks like Intel set the bar wat to low.
100 degrees C in Cinebench R23 at stock. Using a Lian Li Galahad 360 with pump at 100% and fans at 1500 rpm. I was able to get to 83 degrees on my K cpu if I undervolted by 0.0650. My K series CPU has an SP of 79.
Looking at the hand written table from @Robert896r1 mine is not even showing on it, it is that bad. As it currently stands I think i have the worse 12900KS in the world. Just my luck.
@Robert896r1 thank you for that. Just had a quick look at HWBOT. I assume in the for sale section? Trouble is I am located in Australia, so not sure what my chances of finding local or a reputable seller from overseas would be.Go on hwbot forums for binned chips and the voltages they run at.
So far my KS can do 5.2Ghz all cores at 1.250v max package temp is 76 degrees.
5.3Ghz all core at 1.250v = BSOD
5.3Ghz all core at 1.300v = R15 freezes
is that bios set voltage??? what LLC?
So far my KS can do 5.2Ghz all cores at 1.250v max package temp is 76 degrees = R15 pass
5.3Ghz all core at 1.305 = R15 error
5.3Ghz all core at 1.310 = R15 display artifacts, passes, package temp = 85 degrees
5.3Ghz all core at 1.315 = R15 passes, package temp = 85 degrees
Bios set voltage (actual VRM Core Voltage now named in bios 1403)
LLC 7
(on ocn forums there's another user with SP P of 91)
its not directly comparable with 12900K.wow SP84 on a KS!!!!!
that's very very poor
i was hoping they would be all around 100/110 p cores tbh
SP rating is not directly comparable between K and KSwhy isn't it directly?
9900KS was.
just overvolted trash.
looks like they only bin like 2 cores.
