Where you at @Nexus18 ? Someone take your monitor away?![]()
Lol. Poor Nexus
Tomorrow
Back on the ips 34" now, very weird going back! Hopefully have the second one with me for the weekend but not too bothered tbh as far too busy atm.
As for hdr stuff, I only turn hdr on for hdr content and if the game doesn't auto switch for me. I also just keep auto hdr turned on.
Turning it on and off all the time it is then I guessI only turn it on manually for Cyberpunk and then off again when out of the game. Movies auto switch on HDR via MPC-BE though through HDR signal passthrough in MPC Video Renderer. I don't use HDR in anything else or really care that much for it!
Windows itself and apps are not great with HDR being enabled on the desktop. Your brightness will be whack and colours will be whack. SDR all the way.
Oh yea. Forgot about that. I think that's the way to go thenIf you install XBOX Game Bar from the MS Store then it ends up being a simple case of pressing WINKEY+ALT+B![]()
Sounds about right that. As when I had a quick play about 0 seemed darker and 20 seemed brighter. Think I may have left it on 15 myself.Oh yeah, I had a play with that and a value of 10 closely matched the overall SDR brightness when the screen was not in HDR mode so I left it at that. Auto HDR was off of course.
Yeah. Shame. I was hoping it worked seemlesly in Windows 11. But yea, as you say we are a long way off before it all becomes standard. Maybe Windows 12 will have a feature that helps with it that is only on that to make people upgradeYeah that coincides with your preferred brightness too so makes perfect sense. Maybe one day in the not too distant future, SDR<>HDR will be seamless and the native mode on all monitors is just HDR anyway. We are a long way off from that though.
Tried to order but says August for me on Dell website
It can, but the source application/game needs to send the HDR signal direct to the display, then Windows will do the switching. I use MPC-BE for example that does exactly that. Load a HDR movie and MPC Video Renderer (or any other you use that supports HDR passthrough) will trigger Windows to switch to HDR mode. It will then go back when you close the movie.It’s amazing to me that windows can’t flip between sdr and hdr based on content. W11 is such low effort.
Have my 3300 Dell reward points to spend later.
Did you get your vouchers already?
