- 20 Apr 2004
- Rugby
Sad jazz no change for me
You'd think they would hand it over to their partner straight away though, which seems to have happened for some. Overall it just seems very odd.Could be based on location. Those closer to the north could get it more earlier than the south or vice versa
Yeah same story with my tracking. Left the terminal yesterday and they've allegedly not received it at their warehouse.Mine was picked up on the 9th and left the terminal on the 10th. I believe the Syncreon tracker doesn’t work for me as it still says “not received at warehouse”. So I rang them early yesterday and have been told Wednesday for me.
It cost to call the number - found out the hard way lol already up to £8 charges. Two or three of the calls resulted in an automated message that says “no one can take your call right now”
Dell portal just says departed terminal.
I’m not at the delivery address until tomorrow so hope it will be tomorrow.
Oh… i did ask if it was coming by plane from NL and was told no it would be by vehicle.
Although mine was sent over the weekend wanted to double check just in case somewhere in the delivery chain they don’t work weekends.
The AW3423DW comes with a 1.8m DP to DP 1.4 cable.Anyone recommend a decent length Display Port 1.4 cable?
Depends how long you want I suppose. I bought a club3d one a few years back after having issues with the one included with my current monitor, been pretty happy with it and will likely continue to use it with the new monitor, if and when it arrives. Think they do those in either 2 or 3m.Anyone recommend a decent length Display Port 1.4 cable?
