Have you seen your black crush improve. Seen in video by Vincent even better this year with the SOC upgrade then years prior this year when it comes to black crush so hopefully running yours in seeing the change your after?
I was going to check but I think ill run it in as much as I can, they claim 200 hours usage is the magic number I believe. I just gone past the 110 hours used mark so getting there.
I think Vincent noticed less black crush and more shadow detail since he said out of the box settings, so that must have meant he left tone mapping switched on, I think you probably left it switched on also so any crush would have been reduced.
I guess I can leave it on also but as he and others say having tone mapping off gives you more accurate colours. The sweet spot would be to have it off and retain that dark shadow detail and no black crush effect.
. For me usually means slightly more cooler picture then pin point accurate settings.I never seen any significant difference on any of my oled screens after the run in period only slight difference in near black uniformity and banding.I was going to check but I think ill run it in as much as I can, they claim 200 hours usage is the magic number I believe. I just gone past the 110 hours used mark so getting there.
IMO do not bother with what people say in regards to accurate colours or creators intent. I rather go for a picture setting which looks more pleasing to my eyes as blasphemous as that sounds. For me usually means slightly more cooler picture then pin point accurate settings.
It's not the stand itself - there's just a portion of the TV that's as thick as a normal LED TV. You could still buy a slimmer stand or arm/wall-mount it.Was considering an upgrade to c1 48", seems like it takes up about 9" of depth on a desk which is pretty substantial due to the electronics all being inside the stand essentially. Gonna measure it out and see how it looks on my desk, though I think the stand is gonna push it a bit far forwards to be comfortable to use.
Black Friday is the first jumping on point in terms of grabbing it at almost it's best price. If not, wait a year.Think I'll wait for the c2 42 to come down a bit in price after having a read through, less bulky as well so wouldn't be as much of a space hog on the desk.![]()
sounds to me like bad implementation of frame interpolation (dejudder) which LG is known for.during spots people looked like stuttering robots.
I keep flitting between going Ultrawide or 4k, if my maths works out I can get this for approx £1060 (after some time as it results on cashback offers) and the offer is literally today only. I primarily play games like Destiny and I just want to be absolutely certain I'm making the right decision. My issues are because it's main designed function is a TV, will I find frustrations with this because I will mainly use this as a PC monitor?
I was previously tempted by the Alienware 34 UW, but reading what some people have mentioned, they wouldn't put the full retail on it.
Can I ask for everyone’s opinions on this as a desktop pc gaming display with some console use? I’m switching from 2 x 27 inch displays and right now I think I can get this for just less than £1100 today.
originally planned to get this as a display, but no display port put me off initially.
