- 24 Jun 2021
- Oxon
Color Blind Test (#1 Free Color Blind Test)
Take the top-rated online color blindness test at ColorBlindnessTest.org. Detect color vision deficiency and find out if you're color blind in under 2 minutes!www.colorblindnesstest.org
Edit: ooo links kinda fetch some content
Edit2: trying a link with https://www.bbc.co.uk/weather text around it
and a link that is text
I'm pleased to say you'll be disappointed as I can just see the difference in throwup's side-by-side post. I'm not sure it's a worthwhile difference though. The light gray style that Talk Photography and Shooting the Breeze use as default would be a welcome option.Awaiting the 'they look identical' reply...
I don't recognise anyone anymore, everyone has a different face![]()
they are quite a lot different, sounds like your monitor might not be showing enough colors?I'm pleased to say you'll be disappointed as I can just see the difference in throwup's side-by-side post. I'm not sure it's a worthwhile difference though. The light gray style that Talk Photography and Shooting the Breeze use as default would be a welcome option.
Please check the first post in this thread for issues already noted before posting. Thank youThe only two issues I noticed so far.
Same.
And I'm fat.
Nope that's intentional nowOn the whole very good, thank you to those involved in the update.
Quick question - I'm sure that clicking on the post title used to open the first post of the thread, and clicking the envelope to the left opened the first unread post of the thread, now both take me to the first unread post on the thread, is that a setting I need to change or summat else? Had a look through this thread and can't see that mentioned. Ta![]()
