*** Forum Update - Official Issues Thread - Please check the OP for known issues ***
Where's the crying emoji :'-(
:cry:
**EDIT** Actually, tbf it's not that I get notified, they're just all in my 'new posts' feed :(
Definitely liked old avatars far more.
Newer isn't always better.
Move your face closer to the screen :D
That's desktop solution.
For mobile use solution has two alternatives:
1: Move screen closer if having enough strengt in hand to lift device higher.
2: If not, let head fall closer to device.
Page numbers still don’t show in portrait on mobile:
Vs
This is still “broken” but doesn’t seem to be showing in the first post of issues.
Thanks to everyone who’s working hard on this update :).
Have the 'You've posted in this thread' black dots on the envelopes turned orangey pink for anyone else?
If that's been done on purpose, then is there a way to get them showing black again as I'm having serious trouble seeing them with my colour-blindness
Yup
And the envelopes have been redesigned as well.
Better now.*
Just need an online indicator for those that choose to have avatars switched off.
*Just read the bit about colour blindness, I'm sure there'll be a fix.
Yeah, the new envelopes are fine. It's just the 'you have posted' dots that are the issue, I can't see them unless I lean right in. I have to get up and lean in really close, with my nose almost touching the monitor in order for them to be visible.
Put ya specs on.:p
I will mention the dots, pinkish for me also.
Anyway I can make this look better on mobile Android chrome?
Everything is the same size fonts.
Its a bit of a struggle :p
Colour of the icon wasn’t the problem imo, it was the position of it that was ugly. Black icon bottom right = winner.
Thanks for continuing work though!
