- 19 May 2005
It's amazing what goes on during the night, this week I've seen a drunk man stubble around at our gate and someone check to see if our car is locked, all because of the CCTV colour at night.
I did similar but on a much smaller scale for an architect a few years back, I had the cameras uploading a still to an FTP server every few hours. All configured directly on the camera. Proved a reliable set up. If no or unreliable internet then you’d probably want a local FTP server like your Synology.I am looking for help in what to buy to time lapse a new building development next to my house.
I currently have 2off 4MP IP DS-2CD2347G1-LU ColorVu Hikvision Fixed Turrets monitoring my house connected to a Synology with Surveillance Station. This works very well.
This is me standing 1/3 of the way up the field looking back at my house..
I am thinking to hire a spider cherry picker (not sure if thats right name) as conservatory below it and install right at top of gale end for max height
Questions
Is location of camera ok or should I put higher on a pole?
Any better suggestions how to access top of gable end than a cherry picker?
What camera would be best for this? I like Hikvision
I would like to use Surveillance Station but unsure if it can do very long time lapses?
Maybe I could get camera to just save pics direct to Synology?
What interval should I use? Its 90 houses so I expect this to take 1- 2 years
I probably need to get moving with this as they are already marking field and diggers could roll in any day.
Cheers
Yep, i'll dig up a day/night/night with LED comparison for you tomorrow from when I set it up. From memory the picture is significantly better without the LED's on at night, but that's in a pitch black environment with only two small LED solar garden lights on.@Avalon any chance you could share some screens of the footage in daytime / night time? Interested in grabbing some for myself. Cheers
Ajax plus Dahua or Hikvision. I don’t know why you think Hikvision require a high number of updates but in general you get 1 or 2 firmware updates over the life of the camera. I’ve installed many cameras that never had a firmware update.
Thanks. So you'd say the HikConnect app is quite smooth and easy to use?
No idea on the firmware, just where I ordered from had a forum and they mentioned multiple times to stay ontop of firmware updates like at least once a year because backdoors get exposed? I'm not sure.
Is there a specific place to order from as I'm aware Hikvision stopped selling some of their stuff unless you're a professional cctv installer? I have had HikVision before and set it up but never used the HikConnect app/allowed it to be accessed remotely via an app.
Any recommended Hikvision doorbell too?
Any advise on which camera may be best would be a good start for me. the Hikvision cameras I have I think are 4MP, would I be better with 8MP or higher for this?I am looking for help in what to buy to time lapse a new building development next to my house.
Questions
Cheers
I'm trying to find out if a quote I've received is ok.
It's for 3 hilook colour vue 5mp cameras, 1tb NVR £720.
It depends on what the quote is actually for and if it’s supply or presumably supply/fit/set-up? I just grabbed a Hikvision DS-2CD2347G2’s for £85 and £110-120 is easily possible for the LSU/SL, a 7604-NI-K1/4P(b) inc 4TB is £107 delivered via eBay. The HILOOK COLORVU 5MP IPC-T259H is £75/camera for a 5mp ColorVu, so probably £400 for labour? Only you know how awkward the install is, but it doesn’t seem cheap.
Thank you, Seems to be £400 in gear and £300 labour. It's a mid terrace install with the hardest part running the cable through the floor from the front living room to dining room for the rear camera. Waiting on an estimate/quote coming back from another installer but hes using Dahua.It depends on what the quote is actually for and if it’s supply or presumably supply/fit/set-up? I just grabbed a Hikvision DS-2CD2347G2’s for £85 and £110-120 is easily possible for the LSU/SL, a 7604-NI-K1/4P(b) inc 4TB is £107 delivered via eBay. The HILOOK COLORVU 5MP IPC-T259H is £75/camera for a 5mp ColorVu, so probably £400 for labour? Only you know how awkward the install is, but it doesn’t seem cheap.
Any risks from buying on there? Like dodgy firmware of something? Has such thing been heard of if anyone knows?
