Other than use the room for work, I've not really done much else. It's been really nice to use these past few weeks and much nicer than sitting in a bare/cold garage. It's been a real luxury and a good place to be.
I have however wall mounted the Wi-Fi heater:
Only wall mounted it and wired it up today. It seems to heat the room up quickly, but I've not done the CAT6 termination/Cable from the house/Wi-Fi AP yet, so ned to turn it on at the switch, which I can just about cope with!
I have also fitted a third monitor which I got from work, but its a slightly newer model and marginally smaller than the current ones, so I'm gonna need to change it and then finalise the cabling so it is tidier.
The room itself is pretty much finished, but is looking a bit bare.... I'm planning to install a few floating shelves and maybe a Kallax unit and/or some under desk drawers to store stuff in.
So, still some more to do, but I'm gonna try and focus on getting the garage side finished now:
- Plasterboard garage side wall (hopefully next weekend)
- Fit Architrave/Skirting to garage side wall (have some left over)
- Maybe tape and join or just paint the walls... Not sure yet
- Re-instate some workbenches
- Tidy and put up some shelves/racking for storage
Misc jobs:
- Finish terminating the CAT6 in the cabinet (currently using a Powerline Adapter which is fine for work)
- Run direct burial CAT6 cable from house to Garage network cabinet
- Install and setup POE Switch
- Terminal CAT6 and plug into ceiling mounted AP
- Potentially mount a TV above desk...
