- 15 Jun 2012
I definitely acknowledge the 5800X3D is a great processor, even if it's locked.
Now this is my paradox lol. What is the curve optimizer and how do you utilize it for overclock latest gen ryzen? (I am an intel guy right now but I like both brands equally just depends on what they offer to market)
Very odd. Just seems there are multiple things you need to tune on AMD, like lots more to do than Intel chips to get more MHz.
For example, I don't get the vibe that you can just up the multi and the voltage and go from there (like you do with intel chips). Seems AMD has made ability to overclock more difficult?
ie. Most Ryzen overclocks I've seen come out to odd/weird numbers like 4344Mhz or 4745MHz, or whatever it is, it doesn't ever seem to be a nice clean number like 5400MHz on the dot, like you can get very easily with Intel chips. Not sure if you guys are picking up on this but its just as someone who hosts benchmarks all the time I get to measure these small details, and Im curious.
Ok makes sense, just watched some tests on power consumption, the 5800X3D is definitely winning that battle.Yeah, and because of additional cache it doesn't need extra high clock, 4.5 ghz with that cache is comparable to 5.2-5-5 ghz ADL, Zen 3 original version would probably need to have 6 ghz to get similar performance, so i don't see a problem with lower clocks because of 3dcache, clocks will consume much more power than additional cache.
