It's got 25mm conduit (MK) run to where it needs to go with space to install the CSP there if needed, ive put all the draw cables in place ready for it. So there is no need to even go in the loft but that is boarded out.Depending on the engineer you get on the day you might find they are OK to bring the overhead cable into a (boarded, accessible) loft space and put the splice there
Isn't the whole point having it easily accessible outside so they can do repairs easily with no access to the home.
I would never do that, partly because I don't know what that engineers level of work is like which is why I prep stuff all ready for them.Oh in that case you'll be fine. It's when people expect Openreach engineers to be fishing wires inside walls that things tend to come apart quite quickly. You need to have the CSP because the drop cable has to be connected to an internal cable somehow - they can't fit the fibre connector onto the drop cable.
Cable to the house down the wall, splice point, cable back up the wall and inside your house.Normally yes, but there no cables on the front of the house for easy access.
They would need to go around windows and all sorts, so that won't happen easily.Cable to the house down the wall, splice point, cable back up the wall and inside your house.
Cheers! I can imagine, poor guy who did ours was his first day on his own installing it, took him over an hour to get a successful fit that day.It's been spliced for a while now, the field-fit connectors that went onto the internal part of the normal drop cable had too high a failure rate.
Yep.I assume once set up I can just go into settings and change the new hubs details to my old network name and wifi password to save having to re connect all my devices?
So that’s why you can get GFast. Sadly it also means you’re unlikely to get FTTP any time soon.
