True, it's like going from need to want. The more you want the harder it will hurt, but needs are more easily satisfiable. People are adaptable anyway.@Poneros There is a very big difference between playable and good/great fps for some people. Playable to me is what some other people would find great. Sadly I do not have the currency to support my delicate senses 100%![]()
Don't you find that games with crappy graphics usually have really good gameplay and replay ability where as triple A games with the latest and greatest graphics look great but are usually regurgitated same old same old rubbish?Take 7Days To Die as an example, even at 4k the graphics are about as bargain basement as you get but the gameplay is pretty compelling. I think its a better game over Death Stranding which looks gorgeous and is perfectly presented.... and I'm a self confessed graphics snob its been quite an eye opener tbh.
Something has to be in it ....I know its a diff league but look at Minecraft and how popular it is...HL1 or 2 I can play again and again and love themDon't you find that games with crappy graphics usually have really good gameplay and replay ability where as triple A games with the latest and greatest graphics look great but are usually regurgitated same old same old rubbish?
 newer stuff  visually is very pleasing but for what costs...>1k for GPU that will have all bells and whistles on on a 4k....will take lower graphic with better game play any day..Don't you find that games with crappy graphics usually have really good gameplay and replay ability where as triple A games with the latest and greatest graphics look great but are usually regurgitated same old same old rubbish?
If you're fine without the latest in terms of graphics, why buy expensive hardware and 4k displays?Something has to be in it ....I know its a diff league but look at Minecraft and how popular it is...HL1 or 2 I can play again and again and love themnewer stuff visually is very pleasing but for what costs...>1k for GPU that will have all bells and whistles on on a 4k....will take lower graphic with better game play any day..
I am not buying any of themNope.
 I am happy with the old 1060 and 1080p screen that runs what I need fine.True, it's like going from need to want. The more you want the harder it will hurt, but needs are more easily satisfiable. People are adaptable anyway.
Does Diablo Immortal count though? It was originally designed for mobile with all the usual mobile mechanics, and was only ported to PC due to the backlash.I just finished spending 300 hours playing the highly addicted Elden Ring, a AAA masterpiece with excellent gameplay and graphics. And I just started playing Diablo Immortal, a game with old graphics and absolutely garbage gameplay and design that has earned it a 0.8 out of 10 aggregate user score .
I think there is a weak correlation between the two, in that AAA graphics require a large budget and you can't afford to take too many risks with gameplay. While a cheaper game can really experiment with gameplay, in the hopes of standing out.Does Diablo Immortal count though? It was originally designed for mobile with all the usual mobile mechanics, and was only ported to PC due to the backlash.
Personally, I see no correlation between graphics and gameplay at all. It varies too much.
				Ok, so it is safe to say for the same 300 watts we get 50% higher performance?
Have i got that right?
No because the slide does not specify at what wattage the measurement was taken so you can't assume because perf/watt is not a flat line it's a curve
Its probably not going to be like something Intel might do.
You mean like launch a GPU then it may appear in shops at some point??
im going to turn that around to say what I find in developers with good gameplay are reluctant or unable to up their graphics to an expected lvlDon't you find that games with crappy graphics usually have really good gameplay and replay ability where as triple A games with the latest and greatest graphics look great but are usually regurgitated same old same old rubbish?
					www.hardwaretimes.com
				yes.im assuming these cards will be RDNA 3 ?
AMD Radeon RX 7700 XT, 7900 XT Enter Mass Production, Launch Expected in October-November | Hardware Times
AMD’s next-gen Radeon RX 7000 GPUs are set to enter mass production this month, followed by shipments of the GPU kits to board partners in September. The graphics cards are likely to hit retail during the holiday season with an October or November launch. As reported earlier, the first GPU to be...www.hardwaretimes.com
