iCloud+ and Custom Domains for Email
OP
23 Oct 2002
_
I've given up, I finally got it to accept the changes I made to my domain records and then it wouldn't let me add an email address. Any email address.
That's really odd, I didn't have any problems at all at that stage - Do have more than one domain to test with, out of interest?
No worries, totally fair! The lamiral.info site is the author of the imapsync project for what it's worth but yeah, I run imapsync on my own server, far quicker and easier to do a batch of accounts in one go!
Ahhh! :)
29 Apr 2004
Bath
What was the error? On my end my Apple ID was a little messy, the primary email was gmail plus I had icloud and me suffixes as well. I've changed the primary email to icloud which allowed me to delete gmail. Finally I added my new private email to the list.
Commissario
16 Oct 2002
In the radio shack
What was the error?
I posted a screenshot above where I tried to add an email address. After that, I just skipped that stage and added the domain, made the appropriate changes and they were all confirmed in iCloud+ but then it wouldn't let me add an email address, it gave the same error.
Permabanned
9 Aug 2008
29 Apr 2004
Bath
Ahhh sorry the images were blocked on my end I completely missed them. Any movement on the can't add email addy issue today? I'd contact Apple support after that as it looks like something else has a problem if it rejects any email address.
Pez
Pez
20 Oct 2002
Warwickshire
I've just added my domain (theryanfamily.uk) to iCloud+ and created 2 addresses - Setup took 5mins max and all working well.
If it was broken, perhaps try now? :)
29 Apr 2004
Bath
Fab thanks for checking :) Going to set up a 50gb icloud+ as a test to use for SMTP.
Would you mind sending an email from your custom domain, can you clarify if the recieved email has the custom email as the from address and not from the main apple address ?
Thanks
Yep it’s my custom one. You can specify which email to send from in icloud settings.
1 Nov 2007
England
I bought a domain name just to have a custom email address. Once I've actually updated all the websites I'm a user of with my new custom domain address it will be much easier to switch email address providers in the future. The only problem is that it takes a couple of months to update everywhere.
Permabanned
9 Aug 2008
This is why I hate changing email addresses, my personal one stays the same but the one I was thinking about is for a non-profit business. It's cheaper than getting one from 0365 just to recieve email. :)
79p a month is great.
Man of Honour
20 Sep 2006
I moved my domain registrar from GoDaddy to Cloudflare and iCloud didn't like it. I could still send and receive but they kept spamming me messages saying something is wrong and I had to reverify. When I tried to reverify, Apple kept sending me to GoDaddy, rather than Cloudflare. Typically support were useless, trying to blame everyone but themselves. I fixed it in the end by removing the domain and re-adding it. It's a great idea but their 'admin' page is utterly useless for managing it properly.
1 Nov 2007
England
If you want a really good domain registrar then I can highly recommend porkbun.com. I used to use Namecheap but decided I wanted to try Pork Bun after reading decent things about them. I've now moved all of my domains over to Pork Bun. I think I have about 10 at the moment? I'm really happy with them.
Man of Honour
20 Sep 2006
Thanks, but I didn't ask for a recommendation. I'm more than happy with Cloudflare.
Man of Honour
20 Sep 2006
I cannot get this to work. No matter how I set up my MX records it always says "Check your MX records".
Can someone check my domain's records for me and see if I've done something stupid?
Here's mine:
How did you set it up? You should be able to do it all via https://www.icloud.com/settings/#customdomain
Use this link as an idea as to what you need, but the automated process in my first link should do it for you. https://support.apple.com/en-gb/HT212524
