If I didnt know I would have assumed I was looking at POE2.
Yep felt this also.
Visually the games will look similar.If I didnt know I would have assumed I was looking at POE2.
Has anything been mentioned about micro-transactions, after all the backlash around Immortals I’m a little worried about the route Blizzard are going to take with D4?
POE is one of the worst imo. £60 for one skin and everything non-mtx looks horrible. Add to that gambling lootboxes.There be a live service, MTX skins.
Yea blizzard going all cash to play to ensure they get more.
as long its just affect the visual portion and not gameplay I be ok with that.
The way path of exile does it
You might be OK with it but lets not normalize disgusting business practices.
Completely disagree with you there good Sir.Disgusting business practices? wtfCompletely disagree with you there good Sir.
POEs free to play model is the best there is.
I would never go anywhere near Diablo Immortal since it's mobile phone ported trash.If you think PoE's monetisation is disgusting, what on earth do you call Diablo Immortal (and I bet D4 is equally as bad)
MTX is superficial nonsense, you can play the game perfectly fine and have great fun doing all content without spending a penny (although it would be wise to spend £20 on a stash tab budle for QoL)
£20 for a game that will provide you with thousands of hours of gameplay, with quarterly updates and an expansion all for free is pretty damn good value.
Or you can go spend £10,000 on Diablo Immortal and not get a single 5/5 legendary gem.
As far as normal desktop games go POE is easily one of the worst. The game is a pain to play without the tabs and they keep adding new kinds every season. Add to that £60 for one skin, gambling lootboxes and one of the most expensive and underwhelming battle-passes in the industry.
MTX is far from superficial. Whats the point of an ARPG if you don't see your character transform from a guy with a club to a badass looking demigod?
That's some copium. D4 isn't going to be as bad as DI with it's MTX.
Rod Ferguson on D4
He could be talking ***** it's also quite ambiguous but we'll find out in time.
Rod Ferguson on D4
Didn't Cheng also say you wouldn't be able to get gear in DI only for the entire system to be about buying gear basically.
