- 27 Mar 2013
Which bit?That's kinda standard for most people, surely?![]()
Which bit?
That'd fair. The one nearest is actually not that far from work, but then the mrs would have to trust I'd get the right shadeThe travel time. Unless you live next door to one.
That'd fair. The one nearest is actually not that far from work, but then the mrs would have to trust I'd get the right shade.
New sash balance ordered; I went for regular lifters rather than the easylift (coil spring supported). Annoyingly I got to this stage before I realised it was the wrong size...Just thought I'd be a top bloke and clean the sash windows. Top sash collapsed. FML.
Bodged it with 2 screws but now need to source and fit 2 new spiral balancers. Not a problem but I've never done a top only a bottom. Fingers crossed it's easy enough. Annoying as we have sold the place and surveyor was coming last week but I ended up in hospital.
Fin. Don't you love those jobs where when you are done, you are basically back where you were a week ago before it broke?New sash balance ordered; I went for regular lifters rather than the easylift (coil spring supported). Annoyingly I got to this stage before I realised it was the wrong size...
Ordered the correct size; hopefully be here tomorrow.
Finished removing it yesterday.I've started removing the Wisteria in the garden which has been put in the most awkward place. Essentially I have to cut it back every week so I can get past (to the right in the picture) to get to the garden gate so it'll never flower, essentially it's no more than a green and out of control bush really. I'm going to replace it with some climbing roses, which gains me mrs points.
